Buying my first welder. Is this good?
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I am buying my first welder and will be learning to weld on it. I am looking at a new Hobart Handler 187 MIG Welder 230V 180 Amp for 300 bucks. What would you guys suggest?
Re: Buying my first welder. Is this good?
that's a decent welder,buying a decent 220 volt/180 amp welder vs a little 110 volt 140 amp is a smart choice, Ive used them in the past, my freind has one he loves, just don,t forget youll need to get the correct accessories and some welding classes sure won,t hurt, just remember to get the shield gas tanks and gauges and a self darkening face shield, and get a decent fire extinguisher
http://forum.grumpysperformance.com/...hp?f=60&t=1669
http://forum.grumpysperformance.com/....php?f=60&t=72
I bought this one (mig)
http://www.millerwelds.com/products/...llermatic_252/
and this ARC
http://www.mylincolnelectric.com/Cat...t.aspx?p=45349
after using a similar 180 amp mig made by lincoln for a few years
http://www.mylincolnelectric.com/Cat...t.aspx?p=42422
and a little 110 volt 140 amp mig
http://www.mylincolnelectric.com/Cat...t.aspx?p=59618
for the little jobs
and this ARC
for the little jobs
Engine: 355/350
What are the "correct" accessories I should be getting?
Where can I purchase the shield gas tanks and I believe it comes with guages..
your local miller,lincoln, or hobart dealer or local welding supply can rent or sell you tanks, the gases selected depend on what your welding and the wire used, youll want a set of leather gloves and a self darkening face shield at a MINIMUM
http://forum.grumpysperformance.com/...hp?f=60&t=1283
http://forum.grumpysperformance.com/...hp?f=60&t=1108
example
one of my less than smart buddies comes over and I notice hes limping slightly, I ask whats wrong, figuring he twisted an ankle or stubbed a toe, seems he was wearing sneakers and synthetic socks while welding on his car and a bit of molten crap dropped on his sneaker , it burned right thru the fabric instantly and wedged between his big toe and the one next to it and started cooking the surrounding areas, naturally my buddies noticed the process and has started, cussing & hopping around on one foot while trying to remove melted rubber, burning fabric and cooked toes from his damaged sneaker. he finally resorted to hopping over to the sink in the shop and turning on the tap then needed to cut the sneaker off as the cooled molten slag made it really painful to try to remove his foot as it was entangled with now cooled but recently molten plastic and the combo had locked together trapping his toes in the damaged sneaker.
now Im not about to B.S. you guys Ive welded wearing sandals once or twice, so I get dumb at times also, but taking the time to wear a leather apron and engineering boots , and a heavy denim shirt, and keeping a garden hose with a nozzle turned on, near by and a fire extinguisher handy sure seems to be a decent precaution, if you saw my buddies foot you probably would never weld unless you were standing in a 55 gallon drum filled with cold water
all that could be prevented with some cheap,semi-decent safety equipment
http://www.grizzly.com/outlet/Heavy-...ves-Red-/H3145
http://www.grizzly.com/products/Leat...acket-XL/H9888
http://www.grizzly.com/products/Leat...w-42-Bib/H7435
http://www.harborfreight.com/cpi/cta...emnumber=46092
BTW theres a HUGE difference between actually MIG welding and just running flux core wire thru a mig machine
http://www.thefabricator.com/ArcWeld...cle.cfm?ID=929
MIG - (Metal Inert Gas) mig is basically a wire thats fed constantly into the weld area that got current running thru it, it melts both the metal and itself as its consumed/melted by the arc
http://www.autobody101.com/articles/...le=Mig+Welding
MIG is the easiest process of welding. A feeding gun is used to feed a spool of filler metal wire into the weld pool. Current is usually switched on and off by means of a trigger on the gun. Amps are usually controlled by a dial on the MIG machine itself, meaning that you cannot instantly and constantly adjust current in the middle of welding. Though, with some machines you are able to get a foot pedal to control Amps while welding. the shield gas prevents the molten metal from oxidizing, and that significantly strengthens the weld in some applications
read this
http://www.lincolnelectric.com/knowl...sfluxcored.asp
read this
1 Post
Car: 92 Z28
Engine: Boosted LSX
ya molting bb's dont feel good. been there done that. Still do.
Get a good mask. and gloves.
spend all the $ you can on a GOOD welder. You deff. get your $'s worth.
I had a millermatic 250 and liked it.
If i was you Id look at the SP175 older lincolins. or the miller 180's both good machines but should do what ever you want.
buy some scrap metal and tube and just practice,practice,practice. SAFTY deff. comes 1st just remember that. eye protection if you grinding. been to the er a few times to get metal removed from my eye and its not fun.
Engine: 355/350
I bought that one for 300 bucks new in box. :P
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
damn, u lucky bastard thats a $700 welder! how the hell did u get such a deal?
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
I'm looking for a welder as well. Looking to do some custom SFC's. I've been looking mostly at used 110's though cause they're cheaper and my budget is probably too low anyway @ $200-ish...
don,t waste cash on a $200 flux core 90 amp welder theres about nothing thicker than exhaust pipe it will weld or have look good once its done
example
my brother-in -law bought this
http://www.harborfreight.com/cpi/cta...emnumber=94056
it overheats and shuts off for 5 minutes every 3 minutes of weld time and does a less than impressive job even on exhaust pipes
so he returned it and bought this
http://www.harborfreight.com/cpi/cta...emnumber=43550
not that he needed it, but it welds fine, for what he does which is minor repairs and mostly exhaust systems,
now its not nearly the machine this one below is, but its serviceable and cost significantly less
http://www.millerwelds.com/products/...c_212_autoset/
this is a decent buy, (one of my friends bought recently, it does a very nice job on basic repairs)
http://www.welders-direct.com/mercha...t_Code=K2473-1
example
1 Post
Car: 92 Z28
Engine: Boosted LSX
http://www.hobartwelders.com/product...ed/handler187/
So for $300 you got a killer deal.
Engine: 355/350
It's not what you know it's who you know. :P
I have a friend whose dad just passed and he owned a car restoration shop and just wanted to get rid of it. He said he will be giving me a tank too. Didn't describe on what kind but I'm hoping it's the shielded gas tank.
I have a Hobart 135. Amazing how easy it is to weld with it. Good deal there.
example
example
the infos general, and hopefully helpful,not directed at anyone
BTW you WILL occasionally find deals when a fabrication or welding shop or dealership closes, I know one guy that bought a 350 amp miller tig like this
for $6000 that was almost new when a factory closed
http://www.millerwelds.com/products/...driven/big_40/
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
