Threadserts FYI
Car: 86 Sport Coupe
Engine: LG4
Transmission: BW 5 speed
Threadserts FYI
After seeing an article in PHR on using threadserts on the project Laguna I set out to find these, While shopping at Menards I found they sell the tool and aluminum inserts. $9.99 for the tool and 4 different size inserts, and packages of 50 additional inserts for approx. $5-$6 Great for small projects.
Dave
Dave
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Threadserts FYI
are these like a pop-rivet with internal threads or...? how about a link to more info?
what did they use it for on the Laguna?
Car: 86 Sport Coupe
Engine: LG4
Re: Threadserts FYI
They are like pop rivets with threads inside, Just drill hole thread insert on tool pop in hole, squeeze and unscrew tool
Spoiler and window straps on the Laguna
http://www.popularhotrodding.com/tec...ler/index.html
Re: Threadserts FYI
Dave
Dave
Car: 86 Sport Coupe
Engine: LG4
Re: Threadserts FYI
Lowes, Home Depot Menards is a lumber/Hardware type store
Car: '87 Z-28
Engine: LT1-topped 400
Re: Threadserts FYI
Never heard 'em called "threadserts" before, they generally go by the name "Rivnuts." Quite commonly used in aircraft. If you plan on using 'em I'd recommend getting the keyed ones, nothing worse than trying to take out a screw and having the rivnut spin with it.
http://www.aimfasteners.com/rivnut.html
1 Post
Car: 92 Z28
Engine: Boosted LSX
Re: Threadserts FYI
