Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Reflective under hood
Old 03-22-2009, 09:29 PM
sadler's Avatar
Car: 1988 Iroc-Z
Engine: 5.7l 350 TPI
Transmission: 700R4 Auto
Axle/Gears: 3.43 posi
I was thinking about what would be the best way to go about a mirror or some sort of reflective thing under the hood of the car for shows and what not, i have a fiberglass cowl hood, so i'd need something lightweight
Any suggestions for materials or anyone who's done this, didn't find any in search and google came up with mostly murals airbrushed on.
What is reflective like a mirror, lightweight (sort of) and can stand the heat of being under the hood of a car? Also, would this not work at all bc of heat or hood clearance and could I still get this made to put on only when the hood is open at shows? Thanks
Old 03-22-2009, 09:33 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Reflective under hood
polished stainless steel
Old 03-22-2009, 09:38 PM
sadler's Avatar
Car: 1988 Iroc-Z
That sounds like the best route to me too, heard of anyone on here doing that?
Old 03-23-2009, 03:53 PM
89RS_82Z's Avatar
they actually make polished SS pannels for some hot rods
Old 03-23-2009, 05:09 PM
Mathius's Avatar
Aluminum would be lighter, just as reflective, and cost about the same, but be easier to work with.
Mathius
Old 03-23-2009, 05:20 PM
Stephen's Avatar
Car: 87 GTA
You can always just do a Miror Paint, or Chrome Paint.
Obviously, TRUE glass mirrors wouldn't survive driving very well.
Old 03-23-2009, 07:45 PM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
You could buy plexeglass, cut it to fit and paint it with Miror paint
like Stephen said.
Old 03-24-2009, 11:17 AM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
That seems to be popular with Corvette guys. You might try searching one of their forums for idea. I don't think it would be to hard to mirror something that would fit there for shows only, but I think finding something that withstands every day heat will be difficult.
Old 03-24-2009, 01:31 PM
Mathius's Avatar
I keep thinking there's an awful good chance that polished metal would fog up from the heat of driving. Even stainless and aluminum oxidize, which would be enough to ruin his polish job.
Most guys just throw a mirror under the hood at shows.
Mathius
Old 03-24-2009, 01:37 PM
Phoenix8936's Avatar
Wouldn't itbe possible to spray a clear over the metal after its been polished to prevent any oxidation for a long time? its what they have done to wheels, well some of them
Old 03-26-2009, 07:47 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
If your gonna do mirror just buy some mirror plexi.
This stuff was big back in the 80/90's in the mini trucking bask when Iwas in HS.
http://www.professionalplastics.com/ACRYLICMIRROR
Or if you do use a polished aluminum use some of this..
http://www.por15.com/GLISTEN-PC/productinfo/GPCGG/
Stuff works good.
http://www.cecoatings.com/images/polished/DSC04617.JPG
Old 03-26-2009, 10:15 PM
sadler's Avatar
Car: 1988 Iroc-Z
^^ wow those are some good links thanks man!
Old 03-26-2009, 11:17 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
im doing the same thing with my cowl hood.
im hung up on what i want to use to many pros and cons to
stainless and aluminum. . .
Old 03-26-2009, 11:20 PM
FueledSoul's Avatar
what brand cowl to do you have?
Old 03-26-2009, 11:22 PM
sadler's Avatar
Car: 1988 Iroc-Z
what are your pros and cons so far
Old 03-27-2009, 01:17 PM
TGO - 10 Year Member
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Plexi would get close to melting under the hood... You need lexan for heat, but maybe they don't have mirroed lexan...
Paint? The only paint I've seen that is somewhat close to "mirror" is from Alsa corp - and only pics, not in person... They do make a laminate material that is thin / light and actually metal (think, thin sheet of metal) that is reflective... but it too may also melt...
http://www.alsacorp.com/products/mir...irrachrome.htm
http://www.alsacorp.com/products/she...sheetingfx.htm
check out mirror chrome...
http://zoopseal.com/zoopseal.asp
A sealant for aluminum...
If you could get aluminum polished panels, seal with ZoopSeal, would be the way to go...
this guy uses acrylic...
http://cgi.ebay.com/ebaymotors/1998-...spagenameZWDVW
See if they can make some for 3rd gen...
http://www.spinnerpremiumdesigns.com/page3.html
Think that covers it...
Raf
Old 03-29-2009, 09:52 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I don't know how well this stuff would stick to fiberglass, but it's a film that's applied with soapy water, like some decals. This site shows it being applied to the underside of a Honda hood.
http://www.diynetwork.com/diy/ab_par...435297,00.html
Jorlain
Exterior Parts Wanted
06-29-2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
Quick Reply: Reflective under hood
