mid plate
Car: 83-pontiac firebird
Engine: 379ci sbc
Transmission: turbo 400
Axle/Gears: 9in with 410
mid plate
I keep splitting bell housings, has any one put a mid plate in a 3rd gen. f-body with stock motor mounts and stock trans mount? What do i need to do? How hard is it to do? Thanks Tony
camobird@att.net
camobird@att.net
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: mid plate
I don't even use a mid plate. I'd want a removable tranny tunnel before I think about using a mid plate. I use a front motor plate, poly tranny mount and an engine locater to keep the engine moving forward and backward. This is needed when using a front motor plate since it flexes.
If you're breaking the bellhousing, there's too much torque twist somewhere. Get rid of those stock mounts. Use poly or solid engine mounts and a poly tranny mount. If you're still breaking bellhousings after that, chain the engine down to restrict how much it will torque over.
To properly use a mid plate, you also need a torque converter designed for use with a mid plate.
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: mid plate
ive seen mid plates with a flex plate spacer to offset the thickness of the mid plate.
monte87cortez
09-26-2015 08:10 PM
