home built thru the floors and 8 point roll bar
built this for a friend.
i took comp eng, frame tie for there formed rear rails and made them work with the stock frame rails.
i cut angle in the frame ties and plotted them out to fit in the stock rear rails.
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2145.jpg)
rear section is inside the stock rails, and braced with plates in the floor area!
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2146.jpg)
driver side
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2155.jpg)
passenger
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2154.jpg)
pic of the floor bracing
driver side
passenger
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2172.jpg)
Re: home built thru the floors and 8 point roll bar
this being a t-top car i made the main hoop fit in the roof rail to futher stiffen the chassis.
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2157.jpg)
of course the base of the cage is on plate welded to the flooring and body rails.
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2140.jpg)
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2142.jpg)
added plate buy the rear shocks.
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2158.jpg)
to plant the rear down bars too
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2166.jpg)
added plates to the front floors after repairing one side
and put the door bars right on them
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2177.jpg)
for added room i put small bends in the door bars to clear the arm rest's
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2179.jpg)
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2173.jpg)
added the cross bar and the seat brace's
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2175.jpg)
made some seat brackets to fit the driver
driver
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2182.jpg)
passenger
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2181.jpg)
after putting the main hoop braces in and welding it pu soild i painted it all black
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2292.jpg)
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2293.jpg)
made a custom bracket in the spare tire area to mount the battery
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2243.jpg)
put the cut off in the rear tail panel
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2241.jpg)
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2246.jpg)
all the stock plastics fit great!
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2301.jpg)
and it sit's mostly out of site!
![](http://i5.photobucket.com/albums/y196/gearhead559/Tonys%203rd%20gen%20f-%20body/100_2304.jpg)
now im looking for some info on mini tubbing these cars! anyone have good pics of this being done?i may be doing this one, and another one for sure for a friend!
driver
passenger
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Your battery is not track legal. It needs to be inside a sealed box.
im going to be installing a 8pt competition engineering roll cage in my 87 formula 350... looks like u did that right from wat ive seen. only diff im gona do is the front bars im going to have them bent 90 degrees at the end so i can weld the bar maybe 6" off the ground and to the main hoop so i can have maximum clearance since it will be my daily driver and i dont want getting in and out tobe a problem or a pain.
my quesiton is the frame support that u did with the comp engineering subframes... i got the same subframs and installed them through the floor but in a straight line from the front to the rear stock subframes. idk why u cut and welded it into that bend... doesnt seem like it helped in anyway. the welds and cut and welded bends would make it weaker than a straight bar.
wat welder did u use? and argon/C02 75/25%?
Car: 87 IROC L98
I don't see a firewall in any of those pictures so until a firewall is added, it's not track legal. Your firewall will have to seal to the outer fender, not just to the plastic cover to isolate the battery from the rest of the driver's interior.
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
and to be honest, i dont see the fuel cell he is running now.
he wants me to mini tubb it now, and fox body's are cake, but the info on doing them is all over the net. so until the wheel tubbs and rear frame work is done theres no sense in it. and this car has been to the track and they said nothing to him about it
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
![crazy](https://www.thirdgen.org/forums/images/smilies/crazy.gif)
snap on mm140, 75/25
ambainb
04-25-2016 09:21 PM
