Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Does anyone make custom cluster bezels...
Old 07-01-2008 | 09:55 PM
laintocable's Avatar
Car: 89 firebird
Engine: 400 sbc/forged/alum/supercharged
Transmission: TH350, manual valve body
Axle/Gears: posi 390/4 whl disc
I am looking for someone that can make a custom cluster bezel with the original screw ears(to dash). I am installing two 5" Autometer gauges and six 2"5/8. I want to use a stainless steel or aluminum product...More details to anyone that has the ability to fabricate this....Let me know...asap.
Old 07-09-2008 | 03:52 PM
Moto's '91's Avatar
Car: 1991 z28 convertible
Re: Does anyone make custom cluster bezels...
I am also looking for someone who makes custom gauges for '90-'92 Camaros. I need something that will fit AutoMeter gauges. There are several out there, but they are manufactured for '82 to '89 Camaros. If anyone has made these before or knows who makes them, the info would be greatly appreciated. Pictures would be nice too. Thanks.
Old 07-09-2008 | 07:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
you realize that setup wont fit in the stock dimention right?
Old 07-21-2008 | 02:58 AM
86irocu's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3.73 posi
there is a company that makes them. but they are pretty pricy for just a piece of plastic... here is a link... i hope this helps you.
http://covansclassic.carshopinc.com/...7/110-82-50921
Old 07-21-2008 | 11:39 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I have one of those in brushed metal that I bought for my old 83 z28 and it will not work for 90-92. Might be worth a swap but I like the more modern cluster so I hope your good with fiber glass because that is your last resort.
Old 07-21-2008 | 04:57 PM
//<86TA>\\'s Avatar
he has a firebird, not a camaro
Old 07-21-2008 | 08:01 PM
86irocu's Avatar
Car: 1986 Iroc-Z
sorry.. i didnt think to look to the side... he didnt specify...
Old 07-21-2008 | 08:42 PM
PaceFabricating's Avatar
I have made stuff for the 90-92 clusters, I made mine out of alum, for my gauges, I decited not to use it, reson is i found the older dash for my car so im using that, but i can make whatever...
Pacefabricating..
Old 08-04-2008 | 12:37 AM
Moto's '91's Avatar
Can you post pics of what you have made? I don't have any fabrication skills and need to buy a custom guage panel. I am dying to get rid of these crappy guages. Thanks.
Old 03-08-2009 | 10:04 PM
cdh67's Avatar
Car: 84 Z..err 92 now
Engine: 402 LS1 Procharged-14 psi-629 hp!
Something like this?
Attached Thumbnails Does anyone make custom cluster bezels...-blackvinyl.jpg
Old 03-27-2009 | 03:03 PM
1986bluez28's Avatar
Car: 1986 Z28
Engine: 305 for Now
I'm going to try and make one myself. Let you know how it goes. Going to copy my stock one but put the holes where I want.
Old 03-29-2009 | 11:48 AM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Here's one I made for my T/A. Basically used a factory bezel, cut out the center part and made a replacement for it. The whole assembly bolts into the dash just like the factory bezel.
Old 03-29-2009 | 08:43 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Heres the one i made for 90-92 Camaros.
1/4 inch abs plastic, doesn't look pretty on the parts that aren't shown, but installed looks great, i was able to reuse all the stock bolt holes and bolts.
Attached Thumbnails Does anyone make custom cluster bezels...-cluster.jpg   Does anyone make custom cluster bezels...-hpim0254.jpg   Does anyone make custom cluster bezels...-hpim0255.jpg
Old 03-31-2009 | 11:41 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
89******bird is advertising some stainless panels for formulas,
and has expressed interest in some other custom projects.
Try PM'ing him...
I don't know why the editor censors the name, but it has an m,
a u, 2 l's, an e and a t...
Old 04-05-2009 | 11:47 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I made my own dash for my '86. I wasn't going to spend $700 for plastic junk. The panel is flat, so it was a simple matter of making an aluminum plate the same shape and laying out the gauges I wanted. I did do this in AutoCAD because I have the program and know how to use it, but you could do the same thing with carboard templates and trial and error. Remember that a 5" gauge goes into a 4-5/8" hole, don't ask me why that is, but a 5" hole is way too big (the gauge will fall into it). I also made a four gauge pod across my dash to the left of the main cluster. I used mild steel for the body, aluminum for the face plates, and mounted some switches too. I coated the body with wrinkle finish paint and it all looks like it grew threre. People constantly ask me where I bought it (man, that's a great compliment in my book!)
The later model dashes are a bit more complicated, but the same techniques apply. I am finishing up a new cluster I made for my '87 K5 and it is way more complicated than any dash in any third gen. The dash incorporates two AC vents, the heater control panel, the indicator for the the transmission lever, and the radio. I used the same concept though; steel frame with aluminum face plates. I had to carefully cut and weld the aluminum to get the contours right, and I metal finished the welds so it looks like one piece (yes, I'm pretty proud of that). It bolts in like stock, accepts all the stock parts, and also houses a 5" tach and speedo and four other smaller gauges (I used 2-1/16" due to space constraints). It also holds and properly supports a DIN style head unit, which my hacked up stock dash never really did.
The secret to this stuff is all trial and error. Raw materials are cheap. You may need two or three attempts to get what you want. You can always cut and weld and add or remove material. It just take time and patience. No one taught me anything. I read a book, some articles, and praticed a lot. That's the best way to do it.
Old 04-05-2009 | 01:13 PM
Car: 1986 Z28
Engine: 305 for Now
You have any pics of the stuff for the 86? I also have autocad.So is there alot of room behind there so I can pretty much put the gauges where I want to? I'm a tool & Die maker so I have the machines at work .
Old 04-06-2009 | 06:04 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
I'm selling brushed stainless overlays for $60 shipped... PM or email me if you want the details, I have a few left.
Old 04-06-2009 | 06:45 PM
sccavette's Avatar
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
Is that $60 for all 3 pieces? If so how much shipping to 46902?
Phil
Old 04-06-2009 | 06:50 PM
Car: 89 GTA
Axle/Gears: 4.10
Yup, $60 for all three and that included stainless steel button cap bolts and rivets to attach them. Free shipping to anyone in the 48 states!
Old 04-06-2009 | 09:02 PM
sccavette's Avatar
Engine: V8
Well I am impressed it looks really good and that is a good deal! Save one of them for me! Do you take Pay Pal?
Old 04-06-2009 | 09:33 PM
Car: 89 GTA
Axle/Gears: 4.10
I threw together a webpage on my webstore site so you can order it here:
www.beeroutlaw.com/steel.html
Old 01-17-2010 | 09:28 PM
bcfipp's Avatar
Quick style where did u get the 1/4 inch plastic?
Old 01-18-2010 | 11:00 AM
QuickStyle's Avatar
Car: 91 Z28
Bakersfield Plastics. Its a local manufacture.
Frozer!!!
01-19-2024 05:55 PM
Jeremys87
07-14-2022 10:08 PM
tnrednneck
08-13-2015 09:57 AM
ChevyZ71
08-13-2015 08:30 AM
Quick Reply: Does anyone make custom cluster bezels...
