Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Dual Projectors w/HIDs on a GTA
Old 10-07-2008, 11:02 PM
  #51
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Re: Dual Projectors w/HIDs on a GTA
looking great, I like those red backs on the plexi. One day, I want to do that.
Old 10-08-2008, 06:49 AM
  #52
TGO - 10 Year Member
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Cool thanks for the info man. How did you separate the lens from the housing? Did you do the oven trick? If so...can you elaborate?
I wish I could find a set of H6054s H4 housings that have a plastic lens. Most of the ones Ive found are glass...and some of them have glass reflectors too. Separating them didnt go well... haha.
Im going home today, and taking a look at the parts that I have sittin around. I have a set of pop up lights that Im not using, and some spare buckets. So maybe I can do mock up at my APT and then transfer to the car so Im not goofing around in the dark every night. Ill start a new thread and post my progress so I dont hijack yours. There arent enough PROPER HID conversion threads anyway.
J.
Old 10-08-2008, 12:01 PM
  #53
87GTAj's Avatar
Car: 87 Trans Am GTA
Engine: 5.7L TPI
Thanks for the compliment, I really think it sets them apart (even if they're only seen at night, like some say, lol).
...There arent enough PROPER HID conversion threads anyway.
I did use the oven trick. I set the whole thing on a cookie tray, preheated to ~200F, and let it sit in there for a few minutes. After a couple of minutes, I checked it every minute or so until it looked as though the glue was softening. I then quickly and carefully pulled it out, and while holding the lens with an oven mitt, I pryed it off with a long, thin screwdriver. There will still be residue left over on the lens and/or housing, but it's easy to pull off once cooled.
On another set of lights I had, I tried heating the edge with a torch while working around it - BAD IDEA. The heat wasnt nearly uniform enough and crack, bye bye glass. The oven works great.
About the plastic lenses, I agree that there are really none available without glass. I personally like the glass, but here's how you could do plastic:
Remove the lens. Make a mold of the underside of it out of plaster of paris. Take a piece of Plexi/Lexan that is much larger than your lens and build a frame around the edge of it. Stick the Plexi/Lexan into the oven, same way, until it is almost ready to melt. Then quickly remove it and force it over the mold - it will shape to the mold and you have a direct duplicate of your glass lens in plastic.
I was really surprised, too, about the lack of info there was on true retrofitting of HIDs into these cars. That's one of the reasons I went ahead and posted this thread. Get some ideas/opinions flowing.
Old 05-24-2010, 12:13 PM
  #54
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Old thread, I know but a lot of the pictures seems to be broken. Could you update this to fix them? Or is the problem on my end?
Old 05-24-2010, 09:52 PM
  #55
87GTAj's Avatar
Engine: 5.7L TPI
Not sure what's going on, some of the pictures are working fine but some are not - they're all on the same webpage...you can send me a PM with what pics you'd like to see and I can send them to you, or the links if you'd like.
Just let me know.
TX-SleeperC5
02-24-2016 01:34 PM
jer4251
09-16-2015 11:29 AM
Djmathis123
09-08-2015 08:42 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
Quick Reply: Dual Projectors w/HIDs on a GTA
