heres a good one, rotating license plate?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
im playing with idea on how to make my front plate go away, for show purposed only, at the flick of a switch. I have an idea that with a small, cylinder type rotation device, i would be able to go from straight up, then 270 degrees of rotation later have the plate flip flat up under the nose. Im sure a pic would be great but i dont have one.
This sounds great in my head, the only problem is i have no idea if such a rotating cylinder thing exists, i've been browsing through actuators, various little motors and cant really find anything like it. Anybody know another place to look, or know of something i could use?
I know its a weird question but im good for that kind of thing.
edit
i believe what i want would be a rotary actuator, with a 3/4 turn?
edit
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
Re: heres a good one, rotating license plate?
look in Street Rod Mag. I think that is were I seen them they are made for the street rod crowd for that purpose just go to the book store and brows, you will find what you are looking for.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
they did that on mythbusters.
Car: 1988 IROC-Z
Is this what you are looking for?
http://www.mamotorworks.com/corvette-1-0-7789.html
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Also coldn't you use a linear actuator and just hook it to a bracket that pivots on a bolt to make your idea work. Not sure if there is enough ground clearence for the plat to rotate under the bumber though so you might be better with the fold and slide idea.
1 Post
Car: 1986 Firebird
Engine: V6
Transmission: Automatic
A member on here did it. Turned out REALLY well.
Here's alink to the thread which also has a video of it in action
https://www.thirdgen.org/forums/body...-007-cool.html
im not going to screw the plate to my bumper, i dont care how easy it is.
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
ahh, no grill. forgot the trans am had a solid nose
Guess without some funky bracket, they'd make you drill holes in your car. The only exceptions are historical registered cars, which you can barely drive anywhere anyway. Can't wait to move back to PA.
that vette hideaway look like its perfect, seems like its on back-order, i sent them an e-mail, see how long it will take.
sailtexas186548
01-19-2016 12:21 PM
mhatfield 14
10-24-2015 07:48 AM
