can I cancel the tourqe arm and fabricate this?(ford 8.8)
Car: 87 Z28
Engine: 383
Transmission: th350
Axle/Gears: ford 8.8
I wonder If I can do this to the camaro since I have an 8.8 ready
http://gbodyforum.com/viewtopic.php?t=2968
used mustang adj upper control arms,stock lower until i buy adj lower,stock g-body lower by the way
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: can I cancel the tourqe arm and fabricate this?(ford 8.8)
If you think the sheetmetal is strong enough to hold the torque of the diff, you can do anything you want. If it was that simple to do, there would be a lot of cars with that setup already.
There's still a lot of suspension geometry involved in a factory style triangulated 4-link.
it can be done..I have a 84 sport coupe with a 8.8 under it...Its easier when swapping over the ford rear end along with adding upper control arms...all i did was measure the pinion angle on my 7.5 rear end before i removed it...I then transfered the lower control arms mounts to the 8.8 and mounted it under the car with the lower conrrol arms and then set the pinion angle to the stock location and used mustang adjustable upper control arms up top mounted to a 2inch chrome moly tubing cross member...not nealry as bad as you would think,,and it squats and hooks 100% better than the 3 link ever will....the 3 link naturally binds the passenger side suspension up,,it sort of pre-loads it all of the time..have you ever noticed that a worn out 3rd gen usually leans to the passenger side? Its becouse the springs worn out on that side from the abuse..The 4 link sets the suspension evenly and allows for more adjustability.....hope this helps,,Thanks jack
Car: 87 Z28
Engine: 383
Transmission: th350
Hallsresto.com one million thanks to you
do you have any pics for the setup?
eventually i wanted to do a ford 8.8 as well. throw in a good posi or locker and some 31 splines and that thing will be stronger than a built 12bolt ... supposidly... the prob was obviously the tq arm and the 4 link. i would love to see how someone would fab up the 4 link setup. bad thing also is that the axle tubes are really thin and u better know how to weld good or u'll melt through the tube and then ur screwed. i will be putting in a 6 point mild steel cage and prob be ablt to fab something up to that for the upper control arms....
too bad i got a used JEGS tubular shorty tq arm ready to go in... :/ augh! lol
anyone know about the length of the 8.8 vs the 10bolt or 9bolt 7.5"??? also wat was the pinon angle? -1, 0, or 1 degree?
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
If you go this route, you have to ditch the torque arm and panhard rod, since the upper control arms also locate the axle left/right. The panhard rod actually moves the axle to one side slightly as it travels, so it could cause it to bind. I would probably also try to reinforce the sheetmetal area that the uppers mount to, maybe with a crossbrace that ties into the framerails.
i wonder what kind of bracing would be required for the upper control arms.... just a straigh bar of mild steel tubing welded to the sheet metal and side frames?
no one knows the overall length of the ford 8.8 rear and the stock 3rd gen?
no green
01-09-2016 09:22 PM
LT1Formula
10-08-2015 08:34 PM
