Merry Christmas Camaro, K member, Pinto Rack, Torque arm YEY!
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Well this Christmas the Camaro got more presents than I had ever anticipated. I finally dropped it off to have the spring perches welded to my K member, pinto rack and K member installed, V6 springs are being cut and installed, a new torque arm is getting fabbed up and moved to the trans crossmember; and finally while I was dropping the car off at the shop I purchased a full set of Weld Draglite's for the car! It's going to be sitting on 15X10's in the rear, 15X4's in the front and the draglites already have a set of Hoosier 26 10.5's installed! The car's supposed to be done within the month and to round everything out and really put it over the top I picked up 2 new NX Lightning series solenoids! I'll be sure to post up pics of the K member fab work, torque arm, nitrous setup, and all the goods along with new times as soon as the new season starts up.
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: Merry Christmas Camaro, K member, Pinto Rack, Torque arm YEY!
What kind of weight savings do you think you achieved?
I pulled the rims off of the car they were on today, those alone are going to net me at least 60 pounds of weight mostly off the front of the car. The K member weighs less than 1/2 what the stock one does and the stock one with springs and A arms is over 100 pounds. I'm hoping for 29XX pounds race weight with this stuff done to it. It sits at 3200 pounds now but I've got a few other things to change if this doesn't get me there.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
doubt it'll get you there. You'll have to remove a lot more stuff to get to the 2900s
For instance?
Yey for pics, here're the rims, the last one is on the Malibu they came off of, other 2 are of the front and rears. Tires are Hoosier 26X8.5X15's with the D06 compound, fronts are generic metric's that're about 26in tall.
Here's a link to the stock glass hood I found in a junkyard, still needs the 2000 layers of spray paint stripped and some enamel paint laid on it.
http://i254.photobucket.com/albums/h...w/DSC00251.jpg
The new solenoids, these things are absolutly awesome!
http://i254.photobucket.com/albums/h...w/DSC00255.jpg
http://i254.photobucket.com/albums/h...w/DSC00247.jpg
I'll have to go out and get some pics of the K member and such as soon as there's some progress on it.
Yes I've posted on it several times, that's where the pics of my K member and A arms are and a few of the ideas on weight reduction were mine. Unless my math is off I should be right on the verge of sub 3000 pounds. The only other mod I can really think of to do right now would be to install a cage and cut out the crash bars in the door, or install a lightweight battery (which I have).
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Damn, I'm at 2860 with a stock suspension and Iron heads. It doesn't take that much to get there, just depends on how far you want to go.
What all did you do to get your car there?
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Axle/Gears: 3.55
pics of your car.
hey i was going to use cut v6 springs too. can you tell me how much you cut and a pic from the side so i can see how the tire fits.
im doing a k member aswell proably the aje or sphon. mine will be asbc turbo.
but stock height looks stupid looks like a 4wd truck.
Well the car is totally gutted. My dash and door panels are made out of styrofoam, cardboard and carpet. Together they weigh all of ten pounds. All unneeded thinigs from underneath the hood are gone. A/C, Smog, radio with all speakers and wires,Heater and Heater core with all hoses and wires, All A/C ducts, I even gutted my wiring harness for just the bare essentials. I have a factory SMC hood that I just finished I even pulled about 3 pounds of steel out of it and cut out holes in the bottom skeleton to free up another 2 pounds. so it only weighs 35 pounds. 16x8 GTA wheels. I'll post up some pics tomorrow if it doesn't rain. check this thread fora pic of the engine.
https://www.thirdgen.org/forums/auto...ng-engine.html
That engine bay looks good! I'll be able to do that here soon with mine, what type of bracketry did you use and what belts? Since I'm going to be pulling the power steering pump soon and I have no AC it would now be viable to set my engine bay up that way. I have the Heater only box, and my MSD is in a different spot than yours, but I've already dropped the 2 large resevoirs and went with a smaller catch can.
march underdrive pulley and bracket kit. I can't remember the belts right off hand.
Well the car is supposed to be fully done tommorow. The bad thing is I just got surgery done on monday so I'm laid up HARD. I'm still going to try and head out and get pics of the car and drive it home. He ended up fabbing up new mounts for the coilover setup that rides on a perch below the strut tower, and fabbed up a torque arm and possibly a new mount (I haven't been able to talk to him since late yesterday). Anyways we'll see how it goes and if I am in good enough shape to drive her tommorow I'll stop by the truck scales and see what it weighs
Terrell351
06-13-2021 01:13 PM
Linson
08-21-2015 02:12 PM
