Make ur own! demensions of stock LCA/panhard rod!
found my old demensions of stock LCA's and panhard rod!
i took off the old stuff and then made the demensions and then made my own stuff
here they are incase u wanted it
panhard rod:
1 3/8" ends for poly bushings
length: 43" on center from center of each end bushing
41.5" center tubing cut to be notched for 1 3/8" end tubing for bushing... below
41" from end to end of notched pipe, so thats 1/4" of notching on each side.
weld straight and walla! aftermarket tubular panhard rod (non adjustable)
LCA's
using 1 5/8" thick wall mild steel tubing
length: 19 5/16" on center of each bushing end length
i believe its 17 7/16" inner tube length then knotched for outer poly bushing demensions. they are easy to make all u really need are the bushings in hand and the overall ON center demensions.
hope this helps anyone else. ive had these on for over a yr and have had no problems and it really improved my launching/wheel hop/ cornering.
panhard rod:
LCA's
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Re: Make ur own! demensions of stock LCA/panhard rod!
By any chance do you have finish product pictures?. As well as some mid way pics?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I made LCA's using parts from lefthanderchassis.com. I used the AL hex bar, that has threaded ends, then rod ends for one side, and a rubber bushing with a stud welded on it for the other. Voila-adjustable poly/rod end LCA's
And yes, I remember it being 19.3x" long from c-c on the LCA's.
My way is good if you don't want to weld. The AL tubing was about $15 per side, which, with the price of steel pipe is actually pretty good.
yea i got pics, i'll find them and post them. the LCA's are super strong, i used really really thick mild steel tubing and built the welds up to increased strength, im sure there is no aftermarket as strong. i worked for a fencing company at the time, so it only cost me the price of the poly bushings for both
thanks it only took 40 min to make them
i think the panhard rod was 1/8" thick, the LCAs are really thick, id say 3/16-1/4" thick wall tubing. still they are lighter than stock. i used to work at a fencing company so the piping i used was mild steel but thick/strong stuff, u can pick this pipe up for like 3$ a foot or less.
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
That's pretty cool, but what I really need are all of the dimensions for LCA relocation brackets! I've got a buddy who can bend 3/8" steel, so once I can tell him where to cut/bend, it won't be necessary for me to spend the better part of $100 for two C-shaped pieces of metal...
Car: 1982 Trans-Am
Spohns are only $67 I think, and they'd be guaranteed to be the right size. You make your own and if you screw up once you're out that much due to wasted material.
Mine are 1/4" thick, which is super overkill, since you're welding them to 1/8" or 3/16" existing brackets.
I think mine are basically 3 plates welded together, rather than being bent. It's tricky to force them on if they were bent.
Best bet is to make them to suit. Get a few pieces of 3/16" steel and cut them into the basic shape. Lay them on top each other and drill the holes. Then lay them on the existing brackets (on the axle), use the existing LCA hole to align them, and weld them to the brackets. All you're trying to do is lower your mounting point 1-2" or so, how it looks is not too important.
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
nice job customblackbird! u did a great job on thoughs.
thanks jimmy92rs.... u could do the same
as far as the LCA relocation brackets it would be worth the 60$ from UMI to get them bc they are a nice tight fit and come powdercoated so its not that bad, i mean the time u spend making them and the materials u use, metal etc it wouldnt cost all that much to just buy them. my UMI's are a great fit. if u wanted to tho, have some one who has just bought them trace it and send u the demensions or file.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Easiest way to make a custom replacement part is to make a jig to hold the old component. You then remove it from the jig and use the jig to make a custom piece to fit in it's place. No guesswork on dimensions then. Of course the old component can be damaged in any way before making a jig for it. Sometimes that means buying a new factory replacement part first.
thats basically what i did, thats why i gave then the ON center demensions. when i worked for a fencing company i used to just throw together a jig to hold the pipe and i would bang out fences in no time. just makes it a whole lot easier.... u could also get into a business and sell these to 3rd geners everywhere cheaper than the companies do prob
1 Post
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Would the equivalent wall thickness square tubing be stronger?
Which is pricier square or round?
What about the ends, what material would i construct those from.
Off topic, but since i would be in that area, how dramatically different of a ride if i were to cut the rear coils enough to lower it 1-1.5 inches?
How much of a coil would i need to cut to achieve this amount of lowering?
depends, square and round tubing have different torsen qualities. i would stick to round tubing bc its easier to work wit and is strong all the way around. the square tubing is bettter for laterial forces.
the rod ends you would have to purchase. many companies sell them but i wouldnt use them on both sides of the LCA or panhard rod. the ride will be reallly really rough, best to just use one side rod end(side that attaches to rear end) the other side poly or rubber.
cutting stock rear coils will give u lower stance... if your stockers arent sagging low already, but the coil strength isnt enough, the ride will probably suck and get worse. ever see a honda with cut stock springs? look horrible and handle even worse, they just bounce around lol
if your gona cut coils, start cutting small, 1/2 a coil at a time or so. and use a cutting wheel or sawzaw. dont use a torch bc u dont want to create alot of heat... it will weaken the spring and affect the molecules/strength of the spring material
Round/box doesn’t matter, anything in a decent looking size that isn’t going to be a PITA to work with will be strong enough, use whatever you can get cheapest. I used some roll cage tubing the last time I did it because I had a stack of it from when someone cut out a roll cage out of a car, the 2x before that I just boxed the stockers (once with 1-1/4x1/8 strapping and once with pieces cut out of some 16ga sheet metal) because that’s what I had around. All worked equally well.
WRT to cutting coils… the problem is that the spring rate goes up faster with cutting the rear springs then the front so you end up with too stiff a rear suspension and oversteer. With cut front springs or even eibach front springs what I’ve found works best is to pull the insulators out from the top of the rear springs and replacing them with some heater hose, that will lower the back of the car close to an 1”. If you need more cut up to half a coil off the top of the spring. Past that they’ll get too stiff unless you have _really_ stiff front springs, like >1000lb/in, and when you get that stiff you probably won’t want to run the WS6 sway bars, the whole combination is just too much for most people. (this is all assuming that you’re starting with a set of springs that were out of one of the performance models with a v8. Base model ‘bird/rs V8 or any of the v6 springs are a totally different deal).
As far as cutting with a torch… it’s fine if you know what you’re doing, just don’t heat the coils where you’re not cutting. For that matter even if you manage to overheat the next half a coil enough to anneal it (if you’re that bad with a torch you shouldn’t be using it anyway), that’s fine because you’ll find that the first ½-3/4 of a spring coil gets bottomed out in the pocket and doesn’t do anything anyway.
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
where do u guys find the poly bushings to go with your components? I made myself some LCAs and adjustable torque arm a few years ago but just have cheap rubber bushings in them atm as i couldnt find just the bare poly bushings anywhere.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Very nice! i plan on doing the same only with one side with a rod end on each lca and maybe a entire rod end adjustable panhard bar
1 Post
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
If you want rod ends, check out the following links. They make it real simple.
http://www.pegasusautoracing.com/gro...GroupID=RODEND
http://www.pegasusautoracing.com/gro...oupID=TUBEENDS
Thanks race geek, i was wounding about the tube ends that fit in the rods! what a save
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
For poly bushings I just made them out of a boat trailer roller. It was a transparent, yellow piece, that was enough for the LCA bushings and panhard bar bushings. Cheap and easy...
i wonder wat the best size would be for those rod ends. the weldable tube ends that i see come as the largest is 5/8" that means it has to fit into a tube with a 5/8" inner DIA tube correct? and then just get a rod end that has the same thread size?
Car: 1991 Camaro Z28
Engine: 5.0 V8 TPI
I actually started this project two days ago and its going good so far i don't have any pictures of the progress but i have the solidworks rendering. As for the rod end sizes i went with the 3/4 just because that is what you find on one you would buy. For the tube ends i am making my own its time consuming but im at school so i have alot of free time and with a whole machine shop why not. BTW i go to UW-Stout
been looking at something like this
http://store.summitracing.com/partde...5&autoview=sku
but i think im just going to weld a tube to run a bushing on one side then a threaded end on the other to run a rod end
so basically i want to make a set like these:
1 Post
Car: 1987 IROC-Z
Transmission: TH350
^ Thats what I have on my car (but black)... I got lazy and money was easier to come by at the time then the time needed to make them was.
spherical ends on both sides is an all around good performer bc theres not deflection under turning as well as no binding. but they can be harsh for a street car. increased vibration and feeling every bump in the car. poly on each end is bad for the street but great for drag racing. best would be poly end and spherical rod end. less binding and less vibration. just make sure the poly end is the end that attaches to the body not the rear.
where do u get your 3/4" tube ends and spherical ends? id want mine adjustable since im planning on going with a ford 8.8 rear.
Engine: 5.0 V8 TPI
since im making my own tube ends i decided it would be better design to include a hex surface to help tighten the jam nut. Good Idea or Bad idea?
smart idea. but are u really gona need it when its installed on the car? i didnt need one on my UMI PHB. the attached end (poly end) will keep the LCA from rotating. so really theres no need. but u could do it anyway if u wanted to. not sure why all the aftermarkets have that cone shaped end. theres gotta be a reason for it.
Engine: 5.0 V8 TPI
the reason i want to make them like that is because both ends are going to be heim joints and for adjusting because one side is left hand thread and the other is right hand thread so i can adjust it on the car. finaly it will be easier to make im using a cnc lathe and 4 axis cnc mill.
The reason there is a taper on the tube end is so when you put a wrench on your jam nut you can stradal the whole nut and not have the mating surface interfear with the wrench.
here is a link to the drawing for the tube end if anyone wants to make their own http://www.mediafire.com/?nn2w3jmomzz
cant download it but. if u wanted to u could machine the middle of the arm to a hex for a clean look instead of it being on both sides. ive seen this done on someones. or just use HEX tubing.
also where did u get your 3/4 from? and if u look at that UMI pic u see those billet spacer tubes on the ends of the spherical ends.... where do i get those from? i have them on my UMI PHB too.
Engine: 5.0 V8 TPI
For the aluminum spacers i plan on making them my self all they are are two halves that sandwich the heim joint and step the hole down to i think 1/2 inch to accept a 1/2 inch bolt or 5/8 im not sure? im just go turn some out and then cut them to length.
Its so hard trying to make this stuff at school when my car is 300 miles south.
i attached the tube end drawing
#42
Engine: 5.0 V8 TPI
I used solidworks and yes i am using .120 wall tubing and as far as getting some spacers made you should try to find a local college that has an engineering program and ask them if they could help you out or maybe a tech school might also.
#44
1 Post
Car: 1987 IROC-Z
Transmission: TH350
I posted some links a few posts up.
#45
Engine: 5.0 V8 TPI
#46
lilnebel thats where i got my 1.5"x.095" tubing from for my STB. they are alil on the pricey side. they say they are for 1 1/4"x .120 tubing. does that mean the end that fits into the tubing will fit a 1 1/4"x.120" tubing? or that the part of that tube end that slides into the tubing is 1 1/4"x.120"??? they arent clear on that.
when i ordered from them i didnt get an order conformation and i didnt know shipping costs. i got an email saying they recieved the order and would inform me of shipping costs and the order total etc. i went away for 3 days, i checked my email and never heard from them. when i got back it was sitting in my house. 19$ worth of tubing and 19$ for shipping. never got shipping quote or order confirmation lol. not mad tho.
#47
Engine: 5.0 V8 TPI
when you buy tube adpaters the size they give is going to be the size of tube you have. so i am using 1.25" .120" wall tube and the adapter i would get would be 1.25" .120 wall just match the numbers. you dont have to use that size either im using electric weld tube but if you used DOM (drawn over mandrel) you could use a .095 wall chromolly, its more expensive but you save weight.
#48
i looked around alil and i couldnt see the tube adapters for the 1 1/4" x .120? the site he posted is something like 1"x .065" and thats just too thin i believe for a LCA on our cars. i would rather be around the .120" thickness. im also having some trouble finding the 1 1/4"x .120" tubing.
and when u make the LCA does it matter whether its a left or right hand thread? im planning on making adjustable ones for my ford 8.8 swap so if i were to keep a poly bushing on the body mount side and just use a rod end for the rear end side mount wat would i need? left or right hand thread? and could someone post links for a site that sells the rodends/tube adapters and tube?
also idunno if u noticed my chassis shop only sells chrome moly tube adapters and i dont want to weld chrome moly since its a pain in the @ss supposidly. id rather stick to mild steel and just tig it nicely. no headaches
#49
Engine: 5.0 V8 TPI
Im not really sure where you can find the tube adapters i made mine but the tubing you should be able to pick it up at a local steel supplier. Its a real common size. call around and ask for 1.25" by .120" wall, electric weld tubing or if you need to order off the inter net try http://www.discountsteel.com/
#50
thanks thats the cheapest site ive found so far. yea i wouldnt use DOM... no point really. electric weld would be fine.
what about using right or left handed thread for the sperical ends on the rear axle side mount?
