Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
how much balls does a 305 have?
Old 09-10-2007, 10:03 PM
mrpenguin_52's Avatar
how much ***** does a 305 have?
i have an 82' z28 with a 305 and 3 spd automatic, a friend of mine has an 85' z28 with a 305 and 5 spd standard, both of us can't seem to be able to lay a nice clean burnout, now the driver can only be one part of the problem (especially in an automatic), my question is should a 305, ehich is pretty much stock, be able to lay rubber? any comments would be appreciated because i'm soon going to be doing a tranni change to a 5 spd manual because my trani's starting to slip and i'd kinda like to know if that will help my performance out a bit
Old 09-10-2007, 10:10 PM
racerx520's Avatar
Re: how much ***** does a 305 have?
sure, you can lay some rubber...powerbrake it haha, but no, i have a stock 305 with a 3 spd plus o.d. trans, and i cannot get it to lay out rubber jsut by flooring it, i'm sure if you did some nice mods to it, you could or you could just build a 350 for it...that would certainly get the tires i'm sure...maybe an lsx?
Old 09-10-2007, 10:26 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Throw some oil on the ground and that should cure the o'le 305's esteem issues.
Old 09-10-2007, 10:31 PM
racerx520's Avatar
i like that one...that might work on ricers too! i knew this guy who used to have a suped up 88 t/a with a 305, said he used to beat vettes, stock of course, but i think hes full of crap...cuz i cannot see my car beating anew vette anytime soon, no matter what, especially how he didnt seem to have many mods on his
Old 09-10-2007, 10:39 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
a 305 tpi car in good running condition should have no problem laying rubber. Even my friends 86 (peanut cammed) auto equipped car smoked the hides from a stop.
Old 09-10-2007, 11:12 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
I'm kind of curious about this topic. I have a 305 TBI stock cams/heads and if I punch it from a stop it leaves a long patch of rubber (albeit one side ). It even chirps second when doing this. I can also get the rear end to slip if I punch it around a corner.
Old 09-10-2007, 11:26 PM
Jproz1167's Avatar
All in the gearing LOL some had 3.73's/3.42/3.08's maybe the ones that can't have 3.08's.I was going to say just do spinouts on ice but didn't want them to skid off into oblivion is all .....
Old 09-10-2007, 11:59 PM
TGO - 10 Year Member
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Stock 1983 G20 305 converted to TPI with 3.08 gears (G80 gov-lock) and a stock stalled 700r4. Tires are 255/70/R15.
http://youtube.com/watch?v=Oi_n0goatA8
http://youtube.com/watch?v=UEeZ5ruugWA
http://youtube.com/watch?v=PX5Av4pS1RA
Old 09-11-2007, 01:11 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
seen tree oh fives that put out just as good if not better than a 350, build it right, plus when you wax someone and they ask what you got just smile and say its just a 305 also a bad azz 305 is diffrent, its almost like being a rebel LOL............im planing to stroke a 305 when i get some extra time/$$$$ will post what happens......Notice to the left there i got a 305 that barks the tires going into 2nd (700R4 not a 5 speed) with 2.73 and TBI and do a great burn out not PBing ....but its not stock
Old 09-11-2007, 01:27 AM
darkride86T/A's Avatar
Location: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
My 86 T/A has an LG4 305 and 700R4. The only thing done to it
is an intake and exhaust. My current 700r4 is garbage and the motor's
got 199,000 miles on it. On a good day, even with the limp-wristed
P/U truck 700r4 cutting loose between the 1-2 and 2-3 shifts, the old bird
will lay down 10-15ft of rubber. Granted it is a peg leg burnout, but I can do it from a standstill w/o power braking and she's got 2.73's gears!
My car wouldn't do it with 245/50-16's, but I could smoke 215/65-15's right off of the hoops.
Old 09-11-2007, 01:49 AM
89RS_82Z's Avatar
BTW laying rubber with 255/60/15
Old 09-11-2007, 08:08 AM
Jproz1167's Avatar
fast355 did you abandon TBI ???????
Old 09-11-2007, 10:01 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
NO, I abondoned TPI and the 305 in the Van. Went to a TBI 350.
Old 09-11-2007, 11:38 AM
Jproz1167's Avatar
fast355 can a 7747 run a 4.3 TBI v-6? and what kind of chip would be well suited for it with vats and full emmisions?
Old 09-11-2007, 11:41 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The 7747 was the factory ECM for thousands of 4.3 engines. Look in the 1988-1992 astro/safar van and fullsize vans with the 4.3. Most of the S-series trucks had ECMs that were coded different than the 7747. The 7747 does not use VATs. VATs is simply a module that inputs a signal into an ECM such as the 8746 to turn on the fuel flow from the injectors. If the ECM does not require the signal, you don't need to worry about VATs.
Old 09-11-2007, 11:48 AM
Jproz1167's Avatar
so if I just swap a 4.3 chip into my v-8 7747 I can still retain my vats. this is a camaro ecm by the way
Old 09-11-2007, 01:54 PM
CLC85TA's Avatar
Car: 85 Trans Am
Engine: 355
Axle/Gears: open BW 9 bolt w/3.27's
On my carbed 305 before I pulled it, I was able to powerbrake in 2nd gear with a T5 behind it, 3.27 gears, and it spun both. Lots of smoke from the 235's.... Was never able to click 3rd though.
Old 09-11-2007, 02:17 PM
Hammertime540's Avatar
Car: 91 Camaro RS
Axle/Gears: 3.42's Locker
TPI, carb, and well tuned TBI should put some impressive rubber down. I went from TBI to holley 650 double pumper, I don't leave any rubber on concrete without using the brake. But on black top roads I can punch the gas from dead stop and roast the tires as long as I want. I've had a hard time getting traction at the strip with stock tires. They squeal a bit off the starting line, but I think my locker is worn out.
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Depends. If you consider 16 second stock 1/4 miles ballsy, they have *****. LOL. Regardless, even my LG4 305 will power brake (but then again, power braking shouldn't take too much HP)
Old 09-11-2007, 02:32 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
well idk what some of you guys are talkin about cuz my 89 maro 305 tbi 5 speed rips tires all over the place. its basically stock. im pretty sure i have the 308's. plus it studders from a mutilated spark plug that doesnt hit all the time.
Old 09-11-2007, 02:34 PM
Car: 2000 BMW M5
With a manual trans you can do a burnout with a 2.8, which is probably the weakest V6 ever made. It's all about getting power to the tires abrupt enough to break static friction. Once a tire is spinning against the pavement, it takes less power to keep it going.
Old 09-11-2007, 04:47 PM
one wheel peel's Avatar
Car: 84 camaro
Engine: 72 chevy 406 sbc
Axle/Gears: 3.42 eaton posi
my 305 burns em off no prob , with a shift kit she jumps sideways hiting 2nd
3.42 gears and flowmaster exhaust, oh its the l69 305
Old 09-11-2007, 05:03 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
doing burnouts/ spinning the wheels doesn't require alot of power... just lack of traction. A shitty suspension can also make you spin the wheels more. put some bald tires on there and you'll be slipping all over the place. It can be fun at times... but doesn't prove anything in way of how powerful the car is. Fast cars are looking to keep traction, not lose it.
Old 09-11-2007, 05:19 PM
Jproz1167's Avatar
I can honestly say after swapping to a L98 with TBI verses my original LG-4 there is no comparison at all. maybe the later larger cam 305's are different but the peanut cammed 305's will always be slow. My L-98 would leave my original 305 sitting still and theres really nothing special about it. all it has is LO-3 TBI system and a 5.7 exhaust system.Sadly though gas prices and my long commute are ending it's existance under the hood.
Old 09-11-2007, 05:22 PM
Car: 2000 BMW M5
LOL how did I know who this was
Old 09-11-2007, 05:26 PM
Jproz1167's Avatar
haha mr. 327 ...... how goes it .... still gonna be a 4.3 LOL .... the search is on for one right now
Old 09-11-2007, 11:07 PM
89RS_82Z's Avatar
traction action bars, custom panhard, custom torq arm, energy torq arm bush, would put my 305 TBI against a stock or close to stock TPI, brand new tires........like i said before to each there own, and if you are capable of building a 305 that will wax a 350 then do it, and laugh you but off as you tell people all it has is a 305, try a dyno sim program to get a ball park idea on your HP diff. between the 305 and 350 you want to build, pay attention to how much it makes a what RPM and how long it hold that number
oh and BTW you can do a burn out in a tractor with a manual trans, some of us are doing this with autos.... now if you are going to run it at the track then dump the crapy 305 or 350 and get you a 400 or something
Old 09-12-2007, 07:05 AM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Ive got insane wheel hop problems, I'm running 275/60's. Not stock though
Old 09-12-2007, 01:15 PM
89RS_82Z's Avatar
stock suspension?? i used tublar steel and flat steel to make the stock torque arm tighter, and that energy bushing made a differance.....traction action bars will help alot also
Old 09-12-2007, 02:40 PM
dr1
dr1's Avatar
Car: '89 Firebird Formula
Engine: 305 TBI
1 medium sized one and 1 small one.
Old 09-12-2007, 02:44 PM
Jproz1167's Avatar
BB's maybe but hardly *****
Old 09-12-2007, 03:04 PM
Rocksiroc's Avatar
I have an 86 iroc z pretty much stock except for a bigger cam in place of the peanut cam and my car lays rubber no problem at all just with the gas. Also im running 275 tires all around.
Old 09-12-2007, 04:48 PM
3rdGenWillie's Avatar
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
if you have trouble laying rubber it's driver error. my 92 305 tbi 5spd lays it thick w/out brakes, even my 92 2.8 s-10 could chirp 3rd w/245's all around, even my 91 sunbird 3.1 front drive could lay it down.......all about breaking traction
Old 09-18-2007, 09:52 PM
hey, starterof the thread here, im thinkin one of my biggest problems is my trani, czu i'v got the 3 spd auto and its deff. starting to slip (my reverse hardly even works ne mroe) so im in the process of swapping in a t-5, manual from a 84 camaro i just bought for $250...hopefully this will help me out a bit, but another problem might b the fact the i have brand new 235/60/15 's on this car that are giving some good traction but my dad and step dad(who are both car guys) think it should still lay rubber and they've tried and can't get anything out of it either but hopefully this trani will help a bit and im deffinately gunna look into my cam, a couple fo yuo guys were talkin bout 'peanut cam' vs the bigger cam, thanks everyone lol, and keep the posts comin
Old 09-19-2007, 09:25 AM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Well my 305 lays a nice strip, one tire fire with 235/60/15s.
http://s37.photobucket.com/albums/e5...t=IM001179.jpg
http://s37.photobucket.com/albums/e5...t=IM001178.jpg
Me and my friend measured it, 1st gear lasted 200ft and 2nd spun for another 75ish. Almost from telephone pole to pole. No brake used either.
And its mostly stock, mods are as below
Transgo Shift Kit in 700r4
AC Delete
Punched out Cat
Air Intake (flipped filter cover over to let more air in, and got rid of vapor arrestor.)
And its an LG4
Old 09-19-2007, 09:33 AM
Car: 2000 BMW M5
One wheely peelies are very easy to do because when one rear tire is spinning, the spider gears are giving you a 2.0 multiplication over when both tires are spinning. If you can bust a one wheel peel tire loose, the wheel speed will be twice that of if you were spinning posi style, so it will blow it away easy. A posi will make it much harder to spin the tires (GOOD!). I have an LG4 car that will blow away the 3.42 one legger, but that doesn't make up for the fact that it is an outright slow *** car.
Old 09-19-2007, 10:00 AM
Camaro5690's Avatar
Well my 305 isnt that slow at all. As it stand I think it could probably be in the 15.3-15.6 second range, I know its not fast, but its not slow either.
Old 09-19-2007, 10:59 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
been 12.31@108mph on a 1.67 60' time with an n/a *daily driven* 305.
car is no longer daily driven so i'm hoping for something serious with the new trans and exhaust.
Old 09-19-2007, 12:22 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I'm guessing mid to low 13's with my little 305 and it easily lays rubber with 275/40's on the rear.
Heres a fun little video; http://video.google.com/videoplay?do...71967&q=iroc-z
Old 09-19-2007, 12:41 PM
blue82_z28's Avatar
Car: 1982 Camaro Z28 w/ RS groundfx
Transmission: Tranzparts 700r4
Axle/Gears: 3.23's
my old 91 with a 305 tbi could burn out so good, it had the 700r4, when you held the brake and let her loose you would have quite the smoke show, but on my 82 lg4 with my 4 speed stick, i could barely get tire smoke unless if i dumped the clutch at 5k at least.
Old 09-19-2007, 03:57 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
My little 305 can spin the 295/50s from a 20 roll. Most of the time its only one tire lol but it does spin both every once in a wile.
Old 09-20-2007, 08:46 PM
  #42
CG_1985_Z28's Avatar
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
my 305 lays rubber with a borg/warner 5 speed and a powertrax locker in the rear
Old 09-26-2007, 03:00 PM
  #43
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
*****? tink-tink.
Old 09-30-2007, 01:51 PM
  #44
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
My 305 with an LT1 cam, ignition, Magnaflow exhaust, manifolds, aluminum shaft, slippign like a **** auto, 3.42 gears and drag radials will chirp a bit (4 - 5ft).With the old tires we put on it, it just spun till i let off.
Oh, and ever with sticky as **** tires, if it turned a little, it would peel untill i let off the gas.
I know theres a video somewhere here. My buddy john's Stock 305. Just a cam and intake, and a nos shot. Spanking a viper. think it was a 300 shot of nos. The thing ran 11.7 on a stock 305 long block with a peanut cam.
All it needs is an energy drink and their ***** drop
Old 09-30-2007, 06:23 PM
  #45
is a locker just as good as a full posi rear end or are they pretty much the same
Old 09-30-2007, 06:39 PM
  #46
Brisk, those are deffinately some nice burnouts, u have anything done to that 305?
Old 10-01-2007, 12:50 PM
  #47
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i like to think that ground type affects whether or not you leave rubber. that being said mine leaves an awsome smoke show without pbing it. on 235/55/16's. even when i put brand new tires on.
Old 10-01-2007, 01:00 PM
  #48
Car: 2000 BMW M5
Ok I am officially unsubscribing from this post after that remark. WOW. 305 land is a special place.
Old 10-01-2007, 02:07 PM
  #49
Stephen's Avatar
Car: 87 GTA
None. As this Steeda Rustang proved...
TGO thread w/youtube link
Old 10-04-2007, 04:14 PM
  #50
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Ive got an 87 IROC with a stock 305 TPI, stock 700R4, 2.73 gears with limited slip, and 245-45-16's.
All I can do is put it in 1 and squel the tires for about a second. Then it plants you in the seat and goes.
Quick Reply: how much balls does a 305 have?
