86 z28 slicks
86 z28 slicks
I am building a 86 z28 for the track and wondering have any of yall run slicks without putting tubs in...if so do you know what size fits? I will be putting a 454 big block with a poerglide trans. Also need to find out what rear end I can put in to hold the power. If any body knows a person that has built a third gen drag car please let me know . I have a bunch of questions on how to reinforce the frame
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 86 z28 slicks
The size of the slicks will depend on what rpm range you plan on using and the gear ratio. If building from scratch, you stuff the tallest tires possible into the wheel wells then calculate the best gearing to use those tires with the rpm range of the engine.
A 28 x 9 slick will fit with no modifications. A 28 x 10.5 should also fit. Mount them on 15 x 10 rims with 5.5" of backspace.
Slicks are measured across the tread. The sidewall of the tire will be wider. A DOT tire is measured across the sidewall. So a 10.5 slick has more tread than a 10.5 DOT tire.
Is this close enough to a drag car for you?
Re: 86 z28 slicks
I have been trying to get up with you , I think i talked to youre cousin , I would really like to talk on the phone to ask you a bunch of questions about youre car.... youre car is what inspired me.
Car: 87 IROC L98
Re: 86 z28 slicks
I have no relatives so I have no idea who you've been talking to.
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
Re: 86 z28 slicks
what is the closest street tire to 28 x 10.5 slicks? Also would i need to change from 2.73 to 3.73 gears to run a tire that big?
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: 86 z28 slicks
Hoosier QTP 28x11.50-15
both are very close in size and have about a 10" tread.. about that gear, you will want at least a 4.10/4.11(depending on what rearend you use) for a 28" tire.. also depends on how fast your car goes through the traps.. faster cars(11's and faster) will want a lower number than slower cars(12+) since you want a drag car to cross the finish line near the shift point rpm..
1 Post
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: 86 z28 slicks
FWIW, the M/T 28x9 are closer to 27" tall 27.3 IIRC. With 3.73's and those slicks i am going through the top end at 5k, I need to step up to 4.10's really, but if I was pushing a little more hp then i would be closer to the 6K I need to b at.
BADNBLK
Convertibles
65
02-10-2016 03:36 PM
blackz281le
01-11-2016 07:51 AM
