Fiberglass mods, but using existing parts
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
I'm just wondering a quick question, lets say I wanted to change a plastic panel in my car... I like the stock look, but I just want to add a little something extra to it. Is it possible to simply use the existing piece, and just sand down a piece and stick the fiberglass directly to it?
I'm just wondering because I like the stock look, but I would love to maybe take away some of the boxy-ness of the pieces and perhaps add some fiberglass over top of the pieces to help them flow together a little better.
Anyone heard or seen the results of this?
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: Fiberglass mods, but using existing parts
there is a bonding agent on the market to do this. I thinks its made by 3M. You can do it...But the first thing you bump it may break off. Because the plastic is flexable.go to a automotive paint supply place..they'll know what i'm talking about. Use a caulking like gun...Have fun
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
you could always use the stock piece and make some sort of mold, then just make a whole new piece out of fiberglass and round the edges how you want them.
I used bondo hair when working on my door panels, And i fiberglassed over the arm rests from the door and then painted them. They look good i could take pictures tomarow.
LT1Formula
20
11-14-2015 12:02 AM
camaro, car, doors, fabricators, fiberglass, fiberglassmods, generation, installing, jacksonville, keyboard, making, mod, modding, mods, nc
