Body Kit Idea - Nascar Replica
1 Post
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
I was looking at some nascar cars, you know with the Monte Carlo design or w/e. I was thinking, would it be possible to cut the front fascia/bumper and weld on some metal and then some rubber and have the whole peice sit <= 1" off the ground? also extending the side skirts down to about the height. I am not worried bout legal ness, and yes this is for a street car.
Could something like this be feasible? and as far as "what if i get in an accident". Haha my answer is "i dont and i wont". and as far as curbs and hills, that is why there would be a bit of some bendible/soft plastic rubber.
The intent is a sort of nascar replica. opinions???
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Body Kit Idea - Nacar Replica
just get some ground effects and throw a nice paint job on it and slap some company stickers on there.. then get a set of black 15x9's and 15x10's and run 295 rears and 275 fronts
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
You want more like my 2000 Monte Carlo
1 Post
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
that monte carlo is sweet! that's not factory, is it?
I would say on a car like a camaro or firebird, less than 3" of clearnace would be nothing but headaches. Pulling in and out of lots of parking areas would be impossible. Part of the reason is that there is so much body work in front of the front tires. You would tear pieces off in no time. I won't even put lowering springs in my car for this reason. If you decide to do something, though, please post pics...I'd be interested in seeing what you come up with.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Car: 1984 Camaro z28/SC
Engine: 355
Axle/Gears: 9bolt 3.89
Don't destroy a thirdgen to make Nascar crap, destroy any newer model vehicle instead. If you want a Nascar, start with something like bilms Monte Carlo, or another actual car that Nascar styled theirs after, it would be easier and probably look much better. Good luck anyhow though.
I am already planning on something like this, for hill climb/time trial racing, i got the nose piece from five star bodies.
Everyone likes different things, dont get angry when they want to do something that you dont want to see or like, thats what makes some cars unique.
http://rides.webshots.com/photo/2922...45512947bIRQIF
its a 4th gen but similar to your idea.
1 Post
Car: 91 Camaro
1 Post
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
that camaro looks like it would drive in my living room and out the other side with nothing but some scratches, maybe even a machine gun on the roof, then some muddin tires, hideous...
1 Post
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Just think of it this way, we can do what we want to our cars, even though it may lower the value and you think it looks like crap, but we like it, so the value of yours will go up. some of us dont drive garage queens
Car: 89 2.8 RS
Engine: the 2.8
Transmission: 700r4 auto
Axle/Gears: stock one wheel squealer
more likely get stiffer gfx like off an older camaro (82-84) and drop some lowering srpings on your car and set up a slight rake. Put bigger slightly bigger tires on the rear than the front and itll make the car "lean" foward a bit and give the car a nice mean look. the lowering springs should give the appaerance you want and the older ones are much harder. my friend hit the side on a CVS and his just got a small dent that he was able to pop out. They wont get as beat up as newer ones.
Thats the nose i put on mine, except i have cut out the headlight holes and put some lexan over it and the huge hole for cooling. the 2 piece doesnt look bad at all painted, it took some heavy modification to get the fenders to bolt to it and line up right(had to cut the bottom curved part off the fenders and weld a flat piece to the bottom of them to bolt to the bottom part, and do some bending of the curve on the top of the fender, and heat up the top corners of the plastic bumper with a small torch and bend them to fit exact. It was ALOT of work, but it turned out good and noone else has one like me, so it makes me happy.
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Re: Body Kit Idea - Nascar Replica
The skirting in that picture forces air towards the radiator- it's not in front of it.
yeah i saw that after i posted, my bad, i noticed a fairly significant temp change with the skirting being alot lower to the ground at lower speeds ( in town driving about 15-30mph) i had to trim a little because of this but since the nose i fitted to mine has a bigger slant to it than the stock nose, it forces the front end closer to the ground at highway speeds which is the effect i was going for in the first place, and i havent seen cooling issues with it on the highway or on track.
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Very nice, Vader. What type of material did you use and how did you mount it ? The side skirts look like they're flexible ?
http://www.bsrproducts.com/product_i...4ab56be6834173
is where i got mine, same material im pretty sure.
Car: '84 Z28 & '73 camaro LT
Engine: 1960 283, eaton m112 blower
Transmission: none at present, will be manual
Axle/Gears: 3.73:1 lsd
I've always wanted to make my camaro look like a true iroc racing car ever since I had a model of one as a little kid.
I think just adding the fat black or chrome steel wheels and tires and lowering it a bit would achieve much of the look, plus functional louvers on the hood.
There are some new 1:24 scale models that show how great the look can be!
http://cgi.ebay.co.uk/CHEVY-1985-CAM...QQcmdZViewItem
1 Post
Car: 1988 Camaro SC
Engine: 2.8v6
after thinking i will keep my trans am, i really hate the styling of them, i wouldnt mind something different. i would love to make a near replica if possible....but the firebirds are kinda square...so i guess i would have to do it on the camaro.
since the camaros nose is fairly rounded, couldnt i cut the bumper and weld in sheet metal and go from there?
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Terrell351
06-13-2021 01:13 PM
ambainb
04-25-2016 09:21 PM
