Flip ups for Firebirds suck, its a fact..
#51
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally Posted by Klortho
Guess I'm just a die hard purist.
#52
Originally Posted by Stephen
..... Since I just got Sylvania Silver Stars a month ago, it'll be a while before I mod mine. Not gonna waste new bulbs for appearance.
#53
Car: 87 GTA
As in 3 months? 6 months? 9 months?
Maybe I should research the lazy eye mod more. Although, all I can find doing TGO and web searches is that it exists, but nothing more, like anybody who has actually done it, and how it works.
Damn unicorns...
Damn unicorns...
#54
i dont know...i've heard "under a year." But really, you're supposed to change your headlight bulbs once a year anyway. Its what the headlight companies recommend, of course. It probably depends on how often you use them. To me, its like someone telling me to change my battery once a year.
#56
Car: 1991 Firebird with T-Tops
Engine: L03 - 5.0L 305
Considering this is a "unicorn" u should probably just start modding them now and then you'll have them finished by the time your lightsburn out, lol.
#57
Just my thoughts... I love pop up headlights. My dad got an 82 when they first came out, and I can remember making him put them up and down because I thought they were so neat. I cant imagine liking the lines of any other car better than my 87 TA with the lights closed..
That being said, Ill agree that when they are up, they might give the "bright eyed look, frog eyes, etc..". But how often do you drive around in the day light with your lights up??? If I want to be seen, its parking lights and fogs for me. My fogs are bright enough to use by themselves at night. When its dark out...all you see is the light from the bulb. Cant really see the pop up part. Low light situations can make a crappy paint job look awsome...and it can make the pop up look better too. Now for those of you without fog lights, formys, and base birds...if you want to be more visible in the daytime I guess you are stuck.
The only mod so far that I like is the lazy eye mod on dead birds car. I cant remember if he has high beams with that set up...but its the cleanest set up so far. redraifs idea is good too. However she got rid of one of my favorite things about a firebird...but its still a good mod.
I just dont see why something that is usually only used in the dark can be considered to be an eyesore..??
Justin
Justin
#58
Car: 1989 Firebird
Engine: a monster
When taken care off, the 'birds have the best looking lights period. It's the ones that are run down, popeyes, plastics broken and covered with overspray that make them look like crap. As for the plastic bezels, what do you think the C4's had on them? Painted fiberglass, paint the plastic the body color and it would look the same. I'm with the other 'bird purists...keep the lights stock.
Best thing, if you don't like the lights, buy a Camaro
#60
Car: 87 GTA
Too late! What bulbs are in your fogs then ghettocruiser? I do that for short trips, like a mile away from home, and I'm almost there, I don't bother with my pop ups.
#61
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Those have the fiberglass completely around them painted the body color, and insted of flipping up, they spin around wooooooo......
I guess you could say that the C4 lights look just as bad as the 'bird lights then.
But then again, I like both. And the 4th gen dual lights on the '98+ cars even better.
And I too have the diamond cut lights
#62
Car: 1989 Firebird
Engine: a monster
#63
i knew there was going to be atleast one, lol. If you're going to install new light assemblies go with a 55 watt 12 volt bulb, they're very bright and much safer than your old hazed over lights.
#64
also, to get back to MY topic i still have the cardboard version of my headlights but i dont know what to make a negative mold out of. I dont want to make it out of fiberglass because of how hard it is to release fiberglass from steel and also im afraid that the resin will make the cardboard wet and lose its shape.
#65
Car: 87 GTA
I guess I'm goin to try to start fabbong on a set of shorter lights, like 2" x 6" or so. So when my Sylvania Silver Stars go out, I'll be ready.
My fog lights aren't really the 87 originals. They've been replaced, so the lenses aren't fogged, and the housing look perfect, no scratches etc.
#66
1 Post
Car: 1988 trans am GTA
Engine: 350 tpi
i like the firebirds when the lights are down i like them better then the camaros, but when they gotta be up its not that great looking, i agree with the half up looking ones that doesnt look half bad but you can never completely hide your head lights
#67
I wouldn't say a block of wood is your best option but, a stop is all that is required to restrict how far the lamps come up.
I woulld have used different lamps but, these cars aren't piled around the junkyards here.
I modded my housing on the safe side, in case I didn't like the look, so the new lamps can be removed and the old ones put back in with minimal effort.
In the future, I am considering juswt making new frames and not have to worry about desigining around the oem parts. But, that won't be for awhile.
Is a block of wood all that is needed for all years(82-92)? I thought I read somewhere that this would only work for the 87-92's...
#68
Engine: TPI 305/ v6
In all honesty, I cannot say for the 82-86 years as finding motors/frames for them around here is nil.
Aside from knowing billsfirebird (member) has them, I've yet to phsycially see one in a local junkyard to date.
The 'first design' headlamp motors, from what I can tell by looking at a few crappy diagrams I have, they seem to have the limiters in the motor housing rather than being limited by overload (the headlamp module found in 87+ cars)
Without ever having had one orbeing able to dissect one, the above is just speculation.
I'll say again though, I wouldn't use a block of wood for a astop/limiter but.. that's just me.
#69
Lon
#70
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
This is the 1st time I've ever heard of people not liking the pop up headlights on Firebirds. Personally I never liked that people would leave wrenches and screwdrivers on the Camaro headlight openings.
What's not to like about Firebird popups? They give the car a strong look while up and a smooth look while down.
#71
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
<<<< look at the naked blue ball dancing at the blue ***** stripper club.I found some "euro" style lights for trans ams, they seem really nice.
StylinConcepts.com Angel Eye Headlight Conversion
Im gonna get this as soon as Im done with other repairs, Ill post pics.
#73
Axle/Gears: Stock
well maybe so.. but thats one of the few ways to make your ride stand out without losing the stock look.What I would really like though, is to find a way to put 4 lights on it, 2 on each side ( two bulbs in one housing )
#74
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
this winter im going to try and make a headlight conversion to get rid of the flip ups and use regular fixed headlight, i think i may have made a breakthrough and cant wait to work on it. if i get anywhere i will post pics.
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
