Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
smooth firewall
Old 05-20-2006 | 09:50 AM
eric1984z28's Avatar
Car: 1984z28
Engine: soon to have ls1
Transmission: soon to have t56
smooth firewall
anyone done this or have pics of it done on someone elses car?
Old 05-20-2006 | 09:52 PM
Mathius's Avatar
Two shots of third-gen firebird....
Attached Thumbnails smooth firewall-good-pic-1.jpg   smooth firewall-good-pic-2.jpg
Old 05-20-2006 | 09:53 PM
Mathius's Avatar
I think this was a Nova. Can't get much cleaner than that.
Mathius
Old 05-29-2006 | 09:20 AM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
i smoothed mine check out my car domain site for pics
Old 05-30-2006 | 12:37 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Nice job. Looks like you welded in a plate to smooth it, and got rid of the air vents and wipers.
Old 06-07-2006 | 05:38 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
I am in the process of smoothing mine. I cut out a panel to cover the holes. I will be using structural adhiesive to attach it (rather than welding). Then I will use Rage body filler to smooth out the rough edges. I have attached pictures.
Attached Thumbnails smooth firewall-firewall.jpg   smooth firewall-firewall2.jpg
Old 06-07-2006 | 09:53 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Just don't do like this idiot and run the fuel lines through the inside of the car
Old 06-07-2006 | 10:01 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
OH MY LORD!He does have them in the passenger compartment
That thing has obviously never been through tech at a racetrack.
Old 06-08-2006 | 06:28 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
i actually did mine in 2 peices, one for the actual firewall and one for the cowl part. both peices were cut out of 16 gauge sheet metal and done on a cnc plasma.
Old 06-12-2006 | 06:50 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Yeah either that or he has a gas tank hidden behind his firewall.
We need to stop putting warning stickers on happy meal toys! Were eliminating natural selection and thats why we end up with things like this!!!
At least his engine bay looks clean....
Old 06-18-2006 | 06:08 AM
83 Crossfire TA's Avatar
A lot of imports run their fuel lines under the carpet inside the car... I'm mot sure what the rules are tech wise but stock usually flies, so there are at least a ton of fastish subarus and a few others with fuel lines under the driver's seat carpeting...
Old 06-18-2006 | 09:47 AM
Irockz's Avatar
I don't care if it is the way some automakers do it from the factory,fuel lines/cells/tanks,or ANYTHING as volatile as gasoline should not be in the passenger compartment.
Old 06-18-2006 | 09:51 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
It might not be the thing you would do, or anyone really would do, but that doesn't give you the right to call him a freaking idiot. That just makes you sound immature.
Old 06-18-2006 | 09:54 AM
Irockz's Avatar
Facts are facts.
Old 06-18-2006 | 01:11 PM
Car: 88 IROC
Facts are facts.
Sorry CoolTC, but i gotta agree with Irockz on this one. Im not one to flame people for no reason, but you gotta admit that running a flammable/explosive substance in an enclosed passenger compartment is just begging for trouble. It may not even be the fault of the car, what happens when some less than gearhead (ie- GIRLFRIEND) steps on it a couple times while entering/exiting the car? Then next thing you know you have a small gas leak, which at very best will ruin your carpet provided no one lights a cigarette. I mean, is it really worth risking your ride over something stupid like that? Maybe im just gun-shy, checkout my sig and see what happened to my iroc.
Old 06-18-2006 | 02:26 PM
Dialed_In's Avatar
It is illegal for ANY car at ANY sanctioned track to have fuel lines of any sort inside the engine compartment. Two reasons; first of which is the obvious. You don't want the fuel in the compartment in case of a fire. Try to keep the fire outside and away from the occupants. Second is applied to in-car batteries as well and has to do with fumes. You don't want to run the risk of having any kind of dangerous or flamable fumes inside the car. Same reason you must use a sealed and vented battery box.
THe fact that this guy has run the fuel lines through the inside of the car qualifies as an idiot. And yes, he 'should' have been weeded out of the gene pool through natural selection. Maybe there was alcohol involved on the night of his conception
Old 07-02-2006 | 11:13 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Ok Carlin
Old 07-02-2006 | 11:57 AM
Car: 88 IROC
Originally Posted by crrllmich
Ok Carlin
I dont mind being teased but i dont get it. You gotta explain that one to me crrllmich
Old 07-02-2006 | 12:02 PM
crrllmich's Avatar
Engine: L03, LS1
George Carlin. He made a very simular joke to that quite some time ago.
Old 07-02-2006 | 01:50 PM
Car: 88 IROC
Oh i get it. Damn and i thought i had an original.....
Old 07-02-2006 | 02:18 PM
crrllmich's Avatar
Engine: L03, LS1
Dennis Leory did it too.... was even funier because it involved a BB gun lol.
Old 07-03-2006 | 09:22 AM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
Demolition derby cars run a fuel cell in the passenger compartment. They are designed to be wrecked again and agian.
Just my $0.02.
Old 07-03-2006 | 03:09 PM
Car: 88 IROC
Just my $0.02.
Kamakazie pilots wore seat belts and helmets. Doesnt mean it made them safe
Old 07-03-2006 | 07:23 PM
camarokev400's Avatar
mine isnt completely smooth yet, i need to fill the wiper motor hole in and some other small spots
manualbrakes.com
Brakes
63
04-09-2024 12:55 PM
FormulasOnly
07-23-2018 09:47 AM
FormulaEngland
European Region
38
07-17-2016 08:33 AM
mfp189
09-27-2015 10:25 AM
gta892000
09-16-2015 01:40 AM
