non-pop up head lights
#51
Car: Iroc-Z 1985
Engine: LT1 1995
Axle/Gears: 10 bolts, 3.42 with Posi Auburn
Re: non-pop up head lights
Wow ! nice idea ! I am considering this option to modify my headligth on my 88 GTA !
#52
I gotta say... I really like that 77 style front end on the car! Especially with the headlight doors off.
And, I think you might be able to pull this off with camaro headlights...no? It would make mounting the lights really easy, and then just build the 77 style buckets around it. I almost think it will be easier to custom make those openings than adapt the actual parts from the 2nd gen. But I could be wrong.
Will the camaro head light parts put the lights about where they would have to be? You could always adjust them in and out with spaces too.
I hope someone tries this! They'll have to pull their GTA spoiler off if they have one...and fit some sort of smaller tail like the older ones had. That'd be cool.
J.
J.
#53
1 Post
Car: 89 Formula 350
Engine: 5.7 TPI
Now that's worth fabricating! I saw a 77 Firebird and an 86 T/A with decent front ends at the same junkyard. Had I saw this eariler I would have grabbed them.
#54
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Now that is a neat mod!!!! Definitely an alternative to replacing headlight motors and all that other crap.
Actually, you could probably remove the headlight motors and all that other crap, go with these and not only does it look cool but it also helps you lose some weight too!!!
#56
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Heres what i did, still waiting on the headlight control module so they will go up and down, but im happy with them. I used early grand prix bulbs with HIDs. http://s568.photobucket.com/albums/s...view=slideshow
#57
Car: 87 GTA
#58
Car: 1988 Firebird
Well i dont have any pictures but i wanted to utilize the grand am headlight brackets that allow me to adjust the lights as needed, ill try to get pictures later but i really couldn't move them up any more without having to start cutting a LOT more
#61
Car: 1985 Pontiac Trans Am
Engine: 305TPI
i do, but they are not too great of pics, and they are from various stages of completion.
they are great on the street, i think i will adjust them up a little.they are 1x6 inch, and use an h3 bulb. i got them on ebay for $14, plus another $10 for the 100w bulbs, as they only come with 35w.
#62
has anyone seen these headlamps for the nissan 240sx? they are for the flip up style cars, to change them over to non flip up headlamps. there is a set on ebay for $100.00. I want to try an experiment with them but not sure if they are around the same size to cover the hole!http://cgi.ebay.com/ebaymotors/89-90...ht_2126wt_1167
#63
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Make a custom hood if they arent the same size....
#64
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Those 240 lights look nice but I doubt they'll look that good on the car. The lights themselves seemed to be raised a little bit instead of recessed into the housing/socket. So if you were to look at your car from the side, there would be little bubble raised where the headlights are. There is a Corvette running around here like that and it really irks me...
#65
Car: 1990 Firebird Formula
Engine: 305 TBI (L03)
Transmission: THM-700R4
Axle/Gears: GM 10 Bolt
i must be the odd one that was my big turn on to the bird is the concealed headlights i love them (when they work right lol)
#66
Car: 1986 pontiac trans am
Engine: 305 tpi
Transmission: auto
#67
Car: 1988 Trans Am GTA
Engine: 350ci 5.7L TPI
That looks Great man!
can you tell me what type of lights you used?
#68
Car: 87 trans am
Sorry to bring up an old post, but does anyone know where I can get these 1x6 lights that holds a h3 bulb?
#70
Car: 87 trans am
ambainb
04-25-2016 09:21 PM
