Welding pipes while on the car?
1 Post
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I got an all new exhaust system and I'm putting dual exhaust on. I'll be fabbing some of it while installed on the car, specifically while on jack stands and over my head. I've never worked on something like that and I'm curious about any safety precautions. I don't think there is anything besides the obvious watch for anything that may drip down, but are there any other things to watch out for?
since you're welding exhaust you won't have to worry about anything inside the car as the floor pans won't get hot enough. just tack everything up, unbult it, then run full welds. don't try and run a bead while you're working over your head or your just asking for a puddle of molten metal in your face.
As an added precaution, be sure to unhook your battery, so you don't get a surge and fry your CPU. If you can tack it together and get it back out in one piece, then by all means, weld it that way, but if you can't, brazing or soldering would be a whole lot easier.
I don't know what material your exhaust is made out of, but even if it was high quality stainless, you could heat the pipe and just drip some silver solder on the top of the pipe and it would run down nicely.
If you have to weld it together while on the car, make sure you wear leather if you can, and even if you don't, be sure you have no frays on your jeans or other clothing, or you could catch a spark.
Welding out of position can be tricky, are you using a MIG?
Mathius
Mathius
Consensus on the welding forums is that you’re better off with the battery connected. In most cases you’re only using about 20VDC to weld and the battery actually adds a small bit of added protection…
Silver solder will not work anyplace prior or around the cat. Braze might, but to use either you’d need spotless joints with real lap joints.
As far as protection… I know more then one person that has hearing damage from laying under a car with a welder and having one of those super hot goobers roll into their ear. I’ve never bothered myself, but most of them wear some sort of hearing protection now when welding in that position, not to protect them from noise but hot sparks. I’ve had a set of shorts catch fire while welding LCA brackets under the car… Be careful and keep a fire extinguisher handy.
You need a full hood as well as a skull cap and good welding gloves. As suggested before, wear a leather welding jacket if you can. Also consider wearing safety glasses too. This will prevent any "bounce back"...not a pleasant experiance. My personal experiance is to never weld on a vehicle with the battery connected....but to each his own.
Mathius
1 Post
Car: 86 T/A
Engine: HSR 355
Wow, good idea, I'll just tack it then weld when its off of the car. Its going to be ALOT less of a hassle. Thanks guys.
Terrell351
06-13-2021 01:13 PM
transaero
08-31-2015 01:14 AM
