crossfire to crossram??????????
Car: 89 FORMULA355 80 TURBO TA 355
Engine: 355 tuneport 355 chev CARB
Transmission: 700 350
has anyone tried to make a crossfire setup work 4 carb .like the old crossram setup. just tryin to see if this crossram is worth anything more than scrap. let me hear youre ideas
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I came VERY close to trying it about a year ago, and I did alot of research. From what I found, all you'd have to do is make your own top plate to mount two carbs and then create a linkage between the carbs. Do a search on it, and you'll find a few threads by me about doing this.
The reason I didn't do it was because even with two Holleys on top, it just wouldn't make enough power to be worth the effort, becausethe intake base sucks. It would be great as a show peice though!
thanks 4 the imputt thats what iwas thinking , i figured someone has had to try this ..thanks again
1 Post
Don't know if he's around anymore, I haven't really looked. You could do a search on his username and see when he last posted if you wanted to.
I never did see any pics of what he did BTW.
Car: 1986 F250 4x4
Engine: 365HP, 510 lb/ft TQ 460
Transmission: C6
I know this thread is kinda old, but...... Offenhauser still makes Crossrams.
Base part #OFF-5893 $240
Dual quad top part # OFF-5903 $115
Linkage part # OFF-5902 $60
OR
1 pc. CROSSRAM part# OFF-5593 $350
Linkage part # OFF-5590 $70
OR
3rdgenparts
08-06-2015 09:03 AM
