Rear End Spreader
Rear End Spreader
hated to ask because i know the potential for smart *** answers, like "try giving them a couple of drinks first". anyway does anyone have plans or a pic of a rear end spreader? thanks
1 Post
Car: 89 Firebird
http://cgi.ebay.com/ebaymotors/ws/eB...category=34200
Maybe try "rear spreader bar"?
otc or lisle use to have them in the catalog but i couldn't find anything with on line search. yeah tell me about gay ****. basically it's something that would bolt to each side of a center section and use a upper and lower spreader bar deal, usually with right and left hand thread rod ends to open up a rear juts a little to install carreir shims. i'm trying to work it out to use a porta power, maybe with just a couple of angle clips bolted to the center section.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I used one at a truck repair I worked at a few times, it worked well but I can`t remember what brand it was...it hooked into the holes behind the rear cover, you can`t be serious about the porta power?
i made a couple of brackets that a 6ton bottle jack fits in and spreads it. only used it once to get a carrier out of a rearend that they hit in with a sledge hammer
it actually worked pretty good to my surprise
Engine: Many
Transmission: Quite a few
I have a very large c-clamp that we use to squeeze the top and bottom of the housing slightly to unload the bearings. Might be easier/quicker than building something, although possibly more expensive.
Car: 1989 C4
Axle/Gears: 307
So Ede, you want a rear end spreader for Xmas
(Differential Housing Spreader). Ive got one at work cant say I know what brand it is its one of the tools that was in my dads box that I was like WTF is this thing for.
All I see on a quick search is the OTC-7071 which is labled for Dana axles.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
BTW... NSN 4910-00-105-2823 US Army part no. :shrug:
Here is their draft: http://contracting.tacom.army.mil/ma...9-2520-585.pdf
You also may want to 'poke' around some offroad sites or specialty stores. IIRC some jeep diffs needed 'em too.
Car: Tree Huggers
Engine: Do Not
Kids + new cat ≠ sleep
Home > Product Line > OTC® Specialty Hand Tools > OTC Vehicle Systems > Differential Housing Spreader
Manufacturer: OTC
7071 Differential Housing Spreader
Helps you to solve the difficult, time consuming job of removing and/or installing the differential ring gear assembly from the carrier on Dana axle modles 30 -70. Heavy duty device utilizes mechanical screw power to spread the housing, allowing easy removal of the differential assembly, while eliminating makeshift methods that may cause damage to expensive components.
Availability: Usually ships the same business day.
OTC7071List: $437.95Sale: $383.50 (Save 12%)
http://store.autotoolexpress.com/otc7071.html
Or make your own like this:
from: http://i16.ebayimg.com/02/i/01/10/69/2c_1.JPG
Manufacturer: OTC
Car: Tree Huggers
Engine: Do Not
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Holy crap! $229 for the homemade version?!?!?! O.K., that's it! I'm going to get some metal and start fabbing...
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Randy's Ring & Pinion sells them. They are pricey, but if you do a lot of rears, particularly Dada rears they are worth it. Danas stick the shims under the carrier bearings, instead of behind the bearing cups like a GM axel. You'd never get the differentail and bearings into the housing without a spreader, unless the preload was too loose.
You shouldn't need one for a 10-bolt. I've never used one on 10-bolts, 12-bolts, or 8.8 Fords. You absolutely need one for any Dana axel (30, 44, 60, 70) due to the way you set the preload with shims. 9" and 8" Fords, and 8" Toyotas just use side adjusters, which elimate the shims entirely, so you don't need one for them either.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
