Removable Hard top/ T - top Cover / Aero top
Car: 1984 z28
ok so i found out after i started ripping up my t top section that it was a t top to begin with. its spot welded. now i need to make a removable hard top that goes completly over the section where the t tops were. i am thinking about doign this is fiber glass and fabricating it myself. do you guys think this would be hard? also with the weather stripping, could i just cut up the pieces and seal up the thing or would i need to fabricate those also? any input? i could try to get up some pics soon to show you what i mean.
you doing a targa top conversion?
I just scored some lexan T Tops while i'll be essentially epoxying together with a spacer and some bracing so its all perfectly clean and flat.
Unfortunately the T tops are really hurting, plus i don't think i could blend it well enough to leave it all lexan so it's going to have to be painted gloss black...or possibly body color....
1992 Trans Am
05-10-2023 07:19 PM
NBrehm
08-25-2015 11:49 PM
