Question on Drilling and Tapping Threads
1 Post
Car: 1991 Chevy Camaro
Engine: 305 TBI
My AC bracket stud snapped the other day so I am in the process of drilling out what's left of the old stud (stuck in the cylinder head). I know the thread size (or whatever you call it), it's 3/8-16, and I have a drill and a tap and die set. My question is what size drill bit should I use for this? And, does anyone know how far I can/should drill into the cylinder head before I ruin it? Thank you in advance for the help.
http://www.engineersedge.com/tap_drill_chart.htm
your tap set should have that but since it seems it doesn't print it out and save it
Originally posted by 84firebird383
have you tried an extractor yet? why retap it if you dont have to?
1 Post
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
have you tried an extractor? if you have you'd know why he's not trying it.
1 Post
Engine: 305 TBI
Actually I did use an extractor. Since my cordless drill decided to act up on me I went to Sears to get a new one (with a cord!) and I figured I would try some. It worked fine for me but the stud wasn't very tight, it was just broken off in the cylinder head.
1 Post
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I'm glad you decided to give it a try. Alot of time the bolts will be to stubborn to extract, but since you have to drill anyways you might as well try to exract the broken bolt first
