Dual Fans and mounting brackets
I am looking for a dual fan setup with top and bottom brackets. I spoke with someone here who has fans for sale but no brackets so if you have brackets and no fans let me know and we can possibly work it out. thanks this is for 92 camaro
Re: Dual Fans and mounting brackets
Had some trouble finding bolts,... but I found some ! The fans were cleaned/painted but never re-installed. The upper bezel was re-painted and some of the finish is wearing off. There is a scuff in the middle of the shroud and there is a crack over one of the rubber mounts ( NOT cracked around the bolt hole. ) . The center plastic "tab" was cut off too,... it's not used and cutting it off allows a bit more access. Lower plastic mount is in good shape and all hardware is included. ( no wiring )
I would need your ZIP CODE in order to get a shipping quote for you.
