Lower quarter panel pieces
I'm just trying to find out if this is worth anyone's time here, I would need basically lower quarter panel before the rear wheel (between door and wheel) and maybe after the rear wheel too (between rear wheel and bumper).
halfway up / maybe as high as the wheel goes. Both sides and for firebird/trans am. If you have a rust free car with no damage in the rear I can send detailed pics of where to cut etc..
it would have to come from absolutely 0 rust car, CA, FL etc.. IDK, but please keep in mind that new entire quarter skin is $140 so if cutting your car apart is worth it to you for a lot less then please let me know, if you are close to NH/MA I wouldn't mind coming over with a sawzall and doing it myself if you are not up to it.
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
Re: Lower quarter panel pieces
Where. Are you located?
Car: Camaro
Transmission: 6 Speed
Axle/Gears: 9 bolt 370
https://www.facebook.com/ThisWeekInCamaro
1992 Trans Am
05-10-2023 08:19 PM
