help me out....people with slp headers and spohn sfc's
did you just have the problem with the y pipe rubbing against the sfc or did it make it a pain to install the y pipe completely?...
did it make a big gap bye the passenger side collector or hardly
none?
or is my only alternative is an exhaust shop?
none?
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Do you already have the SFC's?
If not then order the version designed for the SLP Y-pipe/Dual cats. Its what I have and there are no clearance problems.
If you already have your SFC's you can try loosening the exhaust connections and adjusting them for clearance while a buddy retightens them. If that doesn't work, you will probably have to talk to an exhaust shop.
redformula88
10-14-2015 06:08 PM
