long tube ground clearance
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I have an unknown brand long tube header on my t/a. It is stock ride height and I have ground clearance issues. I want to lower the car, but that's not possible with these headers. Is there a long tube header out there that will give good clearance?
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: long tube ground clearance
the Hedmans tuck up nice and tight- only maybe 1/2" lower than the frame rail- but the exhaust will need to be run under the crossmember, which will be the lowest point on the car by however big the pipe is...
amfornal
02-28-2016 02:23 PM
