will not putting gaskets on my headers cause oil to come out
Car: 1982 camaro berlinetta
Engine: 5.7 350 swap
Transmission: th350 swap
Axle/Gears: 26 spline 7.5 ring gear
If I don't put header gaskets on my headers will that cause oil to come out from where the heads connect to the headers?
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: will not putting gaskets on my headers cause oil to come out
no . there are no oil passages there . and if youre changing header gaskets go buy the copper ones , they are forever
Thanks rusty and there is oil coming out from the heads
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WC T5
Axle/Gears: Torsen 3.73
That's not good, either oil is getting past the valve seals or piston rings
Car: 1988 Camaro
Yep, if you have oil coming out of the exhaust ports... That is NOT good. Bad rings or valve seals or guides.
Make sure it is in fact inside the exhaust ports though, and not just running down from leaking valve cover gaskets, oil sending unit, etc. I have seen that many times before.
customblackbird
18
11-16-2015 03:02 PM
