Hedman shorties and y pipe, what mandrel bends do I need?
As stated hedman shorties and y pipe. I plan to cut the y pipe right after it merges and and weld 3 inch exhaust from there back. I will be running no converter and already have a flowmaster out back with the mandrel bend over the axle. Also wondering how much straight pipe I should buy?
Also has anyone run a resonator like a dynomax bullet in line with a flowmaster to make it sound a little better and not so raspy? Thanks for any help.
First picture isn't my exhaust, but used as an example. I see a 45 bend going up to the over axle bend (which I have) and then at the front I see another 45 bend.
Last picture is my y pipe. I plan to cut it where the single pipe is welded to the merge to make it 3 inch. They looks to be a 90 and then towards the back another 45.
Any idea how much straight pipe I should buy?
So from that thinking it looks like I need (3) 45 bends and one 90 bend. Can anyone agree or disagree, It maybe obvious it just my first shot at building an exhaust so Idk. Thanks for any help.
LT1Formula
10-08-2015 08:34 PM
