hedman hedders longtube y-pipe
Re: hedman hedders longtube y-pipe
Nice and tight. Looks good.
Any pics of the crossmember?
Here's my modified crossmember to keep the y-pipe as close to the floor as possible. With a 2" lowered car, there's still 3" of ground clearence at the lowest point.
1 Post
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Axle/Gears: 3.23 Australian 9 bolt
That's tucked pretty well! I've been looking for a cross member to use with my auto, and work when I do a manual swap....might have to recreate this....well done!
the crossmember is key. i've done probably 15 of these now and every time i do one, i get a little bit better. the passenger's side primary is dented a little for clearance, but at 3", it's got no issues with flow regardless. i can't wait to fire this car up and see how it sounds.
