side pipes...possible what you guys think
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
okay so I got a 91 firebird that I am about to put some new fenders on the are the pre 90 fenders with the cut outs and since I don't have the plastic things to put in there I want see if I can make my exhaust come out of it and run side pipes. is what I had in mind is cutting the y-pipe where it is now putting an x-pipe of possible then having it come through and out the fenders then done the sides where I attach some purple horny's. you guys think it will work? I have seen a camaro online that has the coming from underneath the car but I think it would look pretty bad *** if the came shooting outta the fender and a whole easy and cheaper to make work.
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Re: side pipes...possible what you guys think
Until someone brands their leg on the hot pipe while getting out of the car.
I love side pipes but not on a 3rd gen.
Is it possible? Anything is possible but that is a major structural area. Unless you do some reinforcement you are going to turn your car into junk
I am not altering anything I am using what is already there how is it altering a structural area
The area behind the fender that you'd have to cut through to get the pipe through is where the cowl, back of the strut tower, "frame rail" and inner fender support come together. On the passenger side it is also where the main wiring harness comes through.
it's not too far from where the y-pipe is so I would just fab an s bend no problem there at all
I was just kinda curious on if anyone had done it and had pics I dunno if it would look good or not
Engine: 4++,350 & 305 CIs
Just don't think it's worth the money, be different or "cool" factor.
I originally was thinking about just doing the x-pipe and then dumping it out the fender hole but I think that would be to loud for street use but for track that might work
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Just do a clean well though out exhaust. Also cut outs are pointless on street cars, but hey it is your car.
Car: 86 Camaro Coupe
Engine: currently building a 355
Transmission: unsure what it will end up with
Axle/Gears: 10 Bolt 2.73
I found this picture of one with side pipes. I know it's not a firebird but its the only third gen I've found with sidepipes so far.
doesn't look to bad but the those rims I think it would look cool to have colored glass packs out there ether some cherry bombs or some purple horny's I like color down low. the more I think about the ground clearance is really low and I have all that plastic GFX that would melt pretty easily I might do it on my 85 T/A though it doesn;t have as much ground effects.
Car: 1990 Trans Am
Axle/Gears: Stock
Well, basically sidepipes ARE possible. We used to have a third gen T/A cruising around our city and it looked quite good.
I'm just not sure whether you'd be able to route anything through the fenders, due to restrictions mentioned by other members further up this thread.
My 87 had side pipes on it when I bought it. It was pretty much duct taped together. It was terrible. He used flex pipe straight off the headers and put them right onto the side pipe inlet. Off the headers he made a over 90 degree angle. Not to mention the side pipes were drilled into the ground effect destroying the one side.
Car: 1989 Camaro Iroc Z
Axle/Gears: 9 Bolt Borg Warner/ 2.77 gear
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
