Need help for headers / heads
Hi all. I am working on getting my motor together to throw in next year and am getting all the parts. I am pretty determined NOT to do the vortec heads, but instead spend my time and money on brand new summit aluminum heads (part# SUM-162108). My question is if these will work with my hooker headers. According to Summt, these heads have angled spark plugs but my cast iron heads did not. would i be able to use my hooker headers on the summit heads, or do i need new ones? thanks!
Re: Need help for headers / heads
I don't know about Hookers headers but I went with angled plug AFR's and they work well with my Edelbrock headers.
The only issue if you have one will likely be the #1 cylinder. I use a shortened spark plug socket made by Trick Flow for that one (see link). I can do my plugs in about 20-30 minutes. Hardest part is getting under the car for cylinders 6 and 8.
http://www.summitracing.com/parts/tfs-90500/overview/
Angled plug head will work just fine with your hooker headers. Get the Acell shorty plugs (They're 1/4" shorter) and I only have an issue getting to the number 6 and 8 plugs on the passenger side because there just isn't much room to maneuver in there and I've got big mits for hands.
evilstuie
02-28-2016 03:33 PM
LT1Formula
20
11-14-2015 12:02 AM
