do stock exhaust manifolds use gaskets?
Car: 1986 Iroc-Z
Engine: 355
was talking to a buddy of mine and he said he doesnt remember having any gaskets on his stock manifolds?
so now im wondering if the stock manifolds on these cars use gaskets? (305 TBI)
Can anyone confirm on this?
I usually always run headers but cant remember anything about stock manifolds
1 Post
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Re: do stock exhaust manifolds use gaskets?
really?? The first time I pulled an engine from my firebird, I thought p.o. had just been a 'tard and not put 'em on lol . Well waddaya know 'bout that.
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I've also seen stock exhaust manifolds without gaskets. GM probably did this on a lot of there vehicles and saved money in the process. I would use gaskets if your take everything apart and putting it back together. I'd say the manifolds sealing surface will deteriorate and warp over time from the exhaust process itself, plus expansion and contraction from the heat. In the end, its probably just fine to use them with out gaskets if the sealing surfaces are ok.
Engine: 4++,350 & 305 CIs
2 freshly machined surfaces like that don't really need gaskets, esp the exhaust which won't leak oil or water. It may leak a little air in or exhaust out but will quickly be covered in carbon.
I think someplace around the 93-97 cars GM started with the steel shim manifold gaskets.
Those stupid cheapy replacement rebuilder type paper/steel gaskets are junk and should never be used because they last about 3 blocks before they blow out.
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Mine had them, no idea if they were there from the factory or not, probably not apparently.
Received 1,845 Likes
Nope; not factory; these motors came with no gaskets. Most motors over the years have been like that.
Machine em flat (or just file em if they're not too bad), and they'll seal MUCH better for a lot longer than any gasket possibly can.
1992 Trans Am
05-10-2023 07:19 PM
transaero
08-31-2015 01:14 AM
NinjaNife
08-23-2015 11:49 AM
