what kind of headers are these?
Car: 86 Camaro Z28
Transmission: TH 700R4
i pulled these today from the junkyard off of a formula but i'd like to know who made em... any help would be appreciated. the flange is 1/4 inch and the tubes are 1 1/2x 1 3/8, the collector is 2 1/2 i.d.
Car: 1984 Z28
Engine: Vortec 350, hotcam
Re: what kind of headers are these?
flowtechs maybe?
http://www.summitracing.com/parts/bi...t/model/camaro
Car: 86 Camaro Z28
yupper.. flowtechs.. now to get the y pipe.. they are looong and i dont think they will fit on my stock y pipe without modification. probably cheaper to just buy the y pipe.
Received 1,839 Likes
Those are the cheeeepest of the cheeeeeeep. You will NEVER get those stupid 3-bolt flanges to stay sealed, especially since they're already visibly bent from over-tightening. You will HATE them. I'd suggest not wasting any further money on them.
Car: 86 Camaro Z28
well good to know, still the first set of headers i've found on an f-body at a scrap yard. guess i'll strip the rust, paint em and sell em. put it towards a nicer set... any suggestions ?...
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
In order of quality,
Dyno Don
Hooker / Hedman is a tie, IMO
Dougs
Jegs ( repackaged Dougs, I'm prety sure)
Dyno Don
Dougs
Car: 86 Camaro Z28
actually i think these are the headers
http://www.ebay.com/itm/180765558361...84.m1438.l2649
looks like flowtech clones, they come with the EXACT same gaskets and bolts that came off of the ones i got from the junkyard. the y pipe from the junkyard looked all shitty and it was 2 maybe 2 1/4 inch (why i didnt waste my time cutting it out)... still a cheezy brand... if i were to go for a cheezy brand i think i'd go for
http://www.ebay.com/itm/150689513706...84.m1438.l2649
they say direct bolt on (i assume that the ones pictured are not the ones that they send) and i really like the y pipe i have and with the money saved i could just jet hot em (won't do me any good if they dont fit though, thats why i havent gotten them yet.... i dont know about them yet because i haven't looked)
Car: 86 Camaro Z28
Car: 91 formula
Engine: 350 tuned port. bolt ons
make sure you get coated headers. My first set of headmens were non coated and started rusting after 1 month or coat them yourself.
just heat wrap them
i have a set of Edelbrock headers which i think are discontinued, and the y pipe, they fit really well and can get to the spark plusg without breaking your arm (no ac or heat atm)
i like the ones i have and the Hooker ones if you cant afford dynodons
Car: 1971 Camaro
Engine: 427
Edelbrocks sucked, tiny collector.
Heat Wrap will only hide the rust, and make it worse. Heat wrap on on coated headers will make them rust out very fast, I have seen it.
Car: 1971 Camaro
Engine: 427
I never said coat them yourself.
In my experince the DIY paints never last. If you can spray ceremic coats and can cure themwith heat, go for it.
Car: 86 Camaro Z28
nope. you're right, formulaforever said that... now to find where i get the ceramic coating and find out if the cost of doing it myself would be less than having it done.
Chad Speier
09-24-2015 12:32 PM
