Header Gasket Woes - D port heads and circle port headers
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
So I slapped on a nice set of Jeg's aluminum heads to my 350 over the past few weekends. Everything went together great! I used some nice fel-pro header gaskets to seal things up between the heads (D-ports) and the headers (1 5/8" Hedman's). Well, they lasted until I hit my first WOT and ALL of the ports blew. I have yet to check the header bolts (ARP's with washers) but I suspect that the gasket seated and I needed to re-torque them and didn't.
I have a couple questions. Since I am using a D-port head with circle port headers, what gasket shape should I be using? The dimensions on the D-port of the head are 1.530"H x 1.545"W and again the port on the header is 1.625" diameter. I assume that since the port on the header is larger than the head, that is a good thing. But it still leaves me a bit confused as to weather I should be using a D-port gasket/circle port/rectangle. Any light you can shed is appreciated.
I've also heard mixed opinions on the Mr. Gasket Copperseals. I'd like to get them as my ultimate goal is to be free from dreaded exhaust leaks, but I'm hesitant to pull the trigger with all the mixed opinions.
Thanks guys.
Thanks guys.
Car: 1986 IROC-Z
Re: Header Gasket Woes - D port heads and circle port headers
I was thinking about running these: http://www.summitracing.com/parts/mrg-7152g/overview/
Use the rounder gaskets that match the headers. If flange is flat a copper gasket will work ok and you can improve that with a little bit of copper rtv. Sealed my turbo car with moderate backpressure til bolts backed out and then developed a small leak
Else look up remflex. Best gasket i used to date. Seals up imperfections and lasts long time. Used it on my turbo car with zero leaks. More expensive but worth it
Part number 2004 or 2005 would cover that. Heads have a big exhaust d port, surprised to see them that big. Remflex has a d port gasket but i dont think i would try that with non d port headers
Car: 1986 IROC-Z
Should be in pairs and they are thick but crush fit down with bolt torque. That way any imperfections are filled in. Sounds like you would need that for yours since they arent perfectly flat. I got mine thru remflex directly
Car: 1986 IROC-Z
Ordering up a set of the 2004's. I had read around online and many people have had a lot of success with these. Let's just hope I don't break them putting them in!
Engine: 4++,350 & 305 CIs
Which fel-pros did you use? The paper and steel ones? Or did they not cover the header port? Are the headers bigger than the exhaust port?
Use the fel-pro graphite coated ones from the performance catalog. (I use 1405 or 6, I cant remember)
Make sure you use the ones that best match your header port.
Use 1" long bolts with a lil dab of anti-seize on the threads. (I buy 2 arp intake kits and use the small head bolts.)
Car: 1982 Camaro
Engine: LTX Carb
Axle/Gears: 3.42 Posi
Honestly the only time that we use header gaskets is on our dyno. What I suggest doing, is cutting the flange in between each tube and making sure the plate is flat with a straight edge, if need be use a file to get them straight/level. We recommend using the High Temp RTV rather than gaskets because they tend to blow out more than what the RTV does. This has really helped the dirt track guys eliminate their exhaust leaks, unless it was improperly done or they hit the area with a pressure washer.
Best Wishes
Best Wishes
LT1Formula
20
11-14-2015 12:02 AM
MoJoe
09-24-2015 09:12 PM
hectre13
09-08-2015 03:38 PM
