exhust for me 305 to 350 swap
Old 12-11-2012 | 11:06 PM
lilman0883's Avatar
Car: 1983 trans am
Axle/Gears: 4 wheel disc 3.23
i have the original manifolds and exhaust all the to back even the y pipe . but i cant use the manifolds on my 350 so can i get manifolds or headers that will bolt up to the ypipe, or do i neeed to have it all replaced
Old 12-12-2012 | 05:18 AM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Re: exhust for me 305 to 350 swap
Others here know a lot more about this than I do, and hopefully they will chime in with some good information for you.
What I do know is that the exhaust system designed for a 305 will significantly restrict the flow of exhaust on your 350, increasing back pressure, and costing you some serious HP loss. If it were my car I would install a good set of headers and than complete the system with one of the better aftermarket dual exhaust set ups. Some companies make a complete package.
Are you required to have a cat in the system to pass inspection in your state? Our state requires the cat to be in place and look functional, however in vehicles older then 15 years old they do not test it. There is a visual inspection to make sure all of the parts are present.
Old 12-12-2012 | 08:35 AM
WyoJames's Avatar
Car: 1987 IROC
Engine: 305 TPI swapped to Holly 4bbl
Transmission: WC T5
Old 12-12-2012 | 12:31 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
3rd gen exhaust systems suck. get a set of shorty headers and a matching exhaust, it's worth it. if you insist on using manifolds, grab a set of LT1 manifolds. They flow way better than just about anything else available manifold wise for a gen 1 motor.
there's no reason the 305 exhaust won't work on the 350, in fact, I wouldn't doubt that the 305 and 350 manifolds are the exact same casting. but as I said earlier, they suck either way.
Jake_92RS
01-28-2020 10:37 PM
bellez77
09-05-2015 08:39 PM
st.evel07
08-13-2015 06:15 PM
armybyrd
08-10-2015 09:23 PM
gwade12
08-08-2015 08:17 AM
Quick Reply: exhust for me 305 to 350 swap
