Exhaust options? Prices, AIR and headers
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Transmission: manual
Axle/Gears: posi
Like many owners, I am wanting to place some headers onto my iroc. I have the 305, but it's in great condition. I have it out of the car to paint the engine bay and figured I would regasket it and do some headers.
Based on my readings: am I to understand that the Y pipe is the main problem? I don't think I have the original Y pipe...it's 3 inches wide. Not sure how to check if it's the original. I do still have manifolds.
That said, I'd also like to keep the AIR system, but I must be frugal with the money. And nearly $600 for either dyno don's or the hooker headers with AIR seems a bit steep; I do know they have a y-pipe too.
Is it ill-advised to get something like the summit racing headers, or some other below $200 set, attach the $80 hedman kit (http://www.summitracing.com/parts/he...t/model/camaro) and roll with my possibly aftermarket y-pipe?
With the summit headers and the hedman kit I'd be at $200. Even if I wanted a y-pipe, most are below $120 so then I'd still be below $400. That's $200 that can be used for other parts, tires, or vacation.
So, my question is: To keep AIR and have headers, why does no one do it this way? Are the below $200 headers that sucky?
And yes, I know, most people some how have tons of money and just buy the uber pricey stuff. But I am a poor mechanic with a family and house and beloved Camaro and I'd like to header my car without losing my house.
Thanks alot folks, I hope to learn something here and maybe be of help to others.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Exhaust options? Prices, AIR and headers
First time you buy anything will do, next you will want something good.
I never understand the waste of money, but I'm sure others do.
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Axle/Gears: posi
I'm not sure I understand what you mean there Don. What I am wanting to know, is how un-wise this route I've explained would be. Or, if it would do. Mind you, it's about $200 off or so from getting your set. So, if the value, longevity, and performance of the cheaper route are much less than the alternative (Dyno Don, Hooker, ect) then I would obviously pony-up and get the better quality. I'm wanting to go a lower buck route here, but if it's not worth it then I can save up or something.
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
Always cheaper to save up and get the good stuff.
Remember you get what you pay for! & You usually end up spending twice as much when you try to go cheapo.
I'm personally saving up for a set of dyno dons+y-pipe. Did a lot of research on his rep & product.
BTW what in the heck is AIR?
Car: 1988 Iroc-Z
Engine: 305 v8 tpi
Axle/Gears: posi
AIR is the smog pump stuff. Stock manifolds on camaros with the smog pump have these little tubes that route to the smog pump.
Man, I was hoping to get by with some money to save, but I guess I'll try to get those Dyno Don's. He really does have a great rep. going on.
I don't have the smog pump anymore, so I guess I won't have to worry bout that....
& yeah its always best to just get the good stuff!
1992 Trans Am
05-10-2023 07:19 PM
LT1Formula
20
11-14-2015 12:02 AM
