classic chambered
Car: 92 camaro RS
Engine: Moded 350 engine
Transmission: 5 speed
classic chambered
somebody must have an opinion on this companies chambered exhaust!!
i am thinking about putting a 26" or 40" powerstick in where the cat goes. that straight line area. then putting just pipes where the stock muffler is. would a resonator be worth putting in the mufflers spot? if so which one??
i was thinking about Hooker 2055 heads, connecting them with y-pipe, and i have duel exhaust tips, fyi.
let me know your thoughts!
http://www.classicchambered.com/index.html
OR i was thinking of putting 2 right nxt to each, and each one takes one engine exhaust bank then putting a y-pipe just before i go up and over the rear axle? since they are quite cheap compared to GMMG
1 Post
Car: 1989 Iroc Z L98
Re: classic chambered
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I've found that having a good length of tailpipe after the muffler tends to deepen the tone quite a bit.
I'd go for it, just lightly clamp it all together and if you don't like it you can change it around.
Just make sure your Y pipe is well made at the back, smooth transitions always help.
I run these on my ls1 car and had one on my L98 back when it was bolt ons. Amazing sounding mufflers. Very mean and rumbly imo.
I gutted the cat and bought the medium powerstick which is 25-26" overall length, and stuck it in the i pipe section, before axle and after cat. Then ran piping up over axle and out rear bumper. Sounded deeep and very mean. I have a dyno vid and another somewhere online i can share.
I got two short powersticks on the trans am ls1 car. One at each bumper outlet. Its single 3" catback with cats on each header collector. It goes from single to dual 2.5" over axle and thats where my powersticks are. With 2 sticks and cats the car is quieter than slp loudmouth 2 i had on it but much better tone imo
Car: 92 camaro RS
thanks for the information!! Appreciate it!
Post any vids or audio that you have Orr89RocZ!!
Car: 92 camaro RS
I thought about it and what I am going to do is put a 20" power stick where the cat goes and then put a resonator (classic chambered has a 12" resonator) at the end. Just a simple, single 3" exhaust.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Idle and full song. Single 3" all the way back, medium Powerstick at stock location, no cat. I don't think I'd do it on a DD, though.
Car: 92 camaro RS
If you put a resonator after a muffler (like the ones that have the stock flow or idea) I put in summits 3in y-pipe and cat back system. No cat. How do classic chambered resonators reduce the noise when it's put after the muffler (part of tail pipe)?. When the muffler is doing the work just before the resonator and the muffler is the one that "drons" in the 1500 rpm range?
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
why you want to add a resonator adding more work than its needed the longs the powerstick the quieter it is on alot of factory cars people remove the resonator to get a better tone and make it louder you can put two powerstick similar to gmmg to tone down the tone and another thing i thought resonators where put on before muffler idea is to tone down the exhuast i think srt 8 have like 4 resonators from factory
What type of sound or tone your trying to get if you want quieter muffler there are other muffler out there as powerstick is the loudest compared to all the catpack systems but about the same as gmmg
tyeo098
11-30-2015 06:27 PM
3.8TransAM
10-01-2015 07:47 PM
84 TA NV
09-06-2015 08:02 PM
