Magnaflow Cat AIR tube too short?
Old 07-29-2012 | 05:40 PM
4rcFed's Avatar
Car: 1989 IROC-Z
Axle/Gears: Just About STOCK
I haven't driven my Z in years and it is time to freshen it up and drive it again. I have had a Magnaflow cat on the shelf for a long time as well. So I am going to start with installing parts that I have already purchased.
Good thing that I did take the old one off, as the honeycomb was in pieces inside.
But just doing a test fit, it looks like my A.I.R. tube is not going to directly hook up. Anyone ever run into this issue?
Old 07-30-2012 | 08:10 PM
4rcFed's Avatar
Car: 1989 IROC-Z
Re: Magnaflow Cat AIR tube too short?
I was thinking of checking to see if NAPA had any kind of tubing but didn't know if they carried anything like that. Plus it looks like the AIR tube is stainless or something, so I can't weld anything up, will need some clamp in solution.
Old 07-30-2012 | 10:28 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Isn't the magnaflow cat a lot shorter than the factory one?
I'm thinking the shorter cat and its all the way to the rear so it moves the air tube farther rearward away from your factory tube..
Set them side by side and compare.
Old 08-02-2012 | 07:38 PM
4rcFed's Avatar
Car: 1989 IROC-Z
Yeah, I've been meaning to put them side by side, so I did that tonight.
As you'll see with the original cat, I already had cut off the AIR tube going into the cat, as I was going to take that down to NAPA and see if they had any piping like that.
It looks like the AIR tube from the engine is some sort of stainless? How about the cat, what is it made of?
And anyone install a Magnaflow cat and run into this issue?
Old 08-02-2012 | 08:20 PM
TTOP350's Avatar
Its stainless, you need to lengthn either tube.
Old 08-02-2012 | 09:15 PM
4rcFed's Avatar
Car: 1989 IROC-Z
Afraid of the fact these are both stainless, can't weld anything. What are the chances that I can find something at NAPA??
Old 08-02-2012 | 09:42 PM
Mikeo91's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
I put that same cat on my 91. NAPA does have an air tube kit, comes with heat resistant hose and clamps. About 30 bucks. Part # exh 35574
Old 08-03-2012 | 04:43 AM
4rcFed's Avatar
Car: 1989 IROC-Z
Nice! U 'da man!!
I'll be checking to see if they have that today.
Old 08-04-2012 | 07:06 PM
4rcFed's Avatar
Car: 1989 IROC-Z
Thank you for the dead-on information Mikeo!!!
Picked up this kit from NAPA the other night. Probably install it tonight or tomorrow.
onefreakz
05-14-2018 12:15 PM
TheExaminer
08-26-2015 04:59 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Magnaflow Cat AIR tube too short?
