16823HKR - Missing hanger?
Car: 1985 IROC-Z
Engine: 383
I just received my 16823HKR from Summit and went to start the install and either a piece is missing or I didn't take a piece off of the old exhaust before I got rid of it a couple of months ago.
Please see the first pic (pipe) below. The holes in the hanger are perpendicular to the holes that mount the hanger. In the 2nd picture (hanger), you can see the type of hanger I have. I looks like a "L" shaped piece would bolt to the exhaust pipe and then slide in the hanger.
I've searched the main parts suppliers and can't seem to find what I need. Can someone point me in the right direction? Not sure if this piece was supposed to come with the exhaust or if it is something I need to buy (and where can I get it?). Thanks.
Car: 1985 IROC-Z
Engine: 383
Re: 16823HKR - Missing hanger?
Upon further searching, I might have found a couple that would work:
http://www.summitracing.com/parts/WLK-35940/
http://www.summitracing.com/parts/WLK-35358/
Does anyone know which of these (if either) would work better? Seems to me something that should have come with the exhaust, unless (as I said) I somehow left it on the old one...
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
make something- it's just a 90 degree angle and a couple of holes in a piece of steel.. but make sure you use something to isolate the exhaust from the body.
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
I put the same catback on my 88 and yes your missing a hanger from the rail.... let me know if you've made it fit already.. if you dont get it on there right youre gonna have a noise back there lol
