Open Headers Question
I have a 91 305 TPI 5 speed. I've heard the computer is finicky about exhaust changes on the speed density models like mine (90 and up I believe). I'm really desiring open headers but wondering about the possible consequences. Will it affect my gas mileage or power either in a good or bad way? Will I get a check engine light? I'm not talking about stock manifold... but legit 500+ dollar, aftermarket headers.
I live in California so it's obviously very much illegal but I ran open downpipe on my STI and just stayed out of throttle when cops were around and they didn't mess with me. I know nowadays most look down upon this and consider it ***** or cheap but know that I'm not doing this for the sound. I'm trying to get the most efficient power possible which I've heard is either no exhaust or straight pipes.
Engine: 4++,350 & 305 CIs
Re: Open Headers Question
Yikes....
1 Post
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Lose of gas mileage,a gutless turd with no low end torque at all.
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
OP, have you ever driven a 3rd gen with open headers?
it's fun for about 5 minutes... then you start having thoughts about exhaust getting back up into the car and knocking you out, fires, HUGE tickets and fines, headaches, etc..
I drove around town once with open longtubes in my '82 T/A, never again.
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Yeah not a good idea man. A turbo car's exhasut is never as loud as an NA car's. I stared up my TPI 305 with just the stock Y-pipe when the cat went bad and not good sounding at all and very loud. Right now I have a 24" summit glass pack in place of the cat with a about a 1" spout and it does not sound too bad, but does get loud when you get on it. last year I had a 72 Nova with a mild 307 in it. It had Headman long tubes on it and when i did the muffler swap I drove it around for a few with just the header and about 5' of pipe coming off them. I did not like the sound one bit and the car lost some low end as well. I was very happy to install the new Flowmaster 40's lol!
Open headers are cool on a built engine and on the track or off road.
I'm not new to cars but I am new to V8. My previous cars were 06 WRX, 01 S2000, 04 Neon SRT4 and a turbo Civic. With the turbo cars a full turboback exhaust and tune easily gets you 70 hp/tq at the wheels (very lean). I'm not used to NA V8.
Like everybody else I want the most bang for the buck. My 305 is the 5 speed so it has good pickup but I'm used to 350+ whp cars and want more.
If you guys think open headers are this bad how about custom headers+exhaust vs aftermarket? Any cheap/best gains set ups that you guys know of? I looked into hooker headers but I read that they don't work with my 2 cat system (91-92 speed density 305's).
1 Post
Engine: LB9/3.1
Really? My WRX was LOUD AS FU** when I ran open 3 inch DP. The turbo spool alone was louder than an 18 wheeler's. I just don't want to pay 500+ for a good exhaust. I want to be able to afford headers+full exhaust for around 600-700 tops. I'm debating custom headers and exhaust but I know they usually use crush bent rather than mandrel.
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
You won't get far in CA with open headers on a v8. It's loud just at idle!!! But, let us know just how far you do get. I'd say as far as the first cop car.
Well your WRX might have been loud, but I have be around alot of built turbo cars and did not have much of an exhaust and they are not a loud as a V8 with no exhaust. Sadly if you are use to thoes pocket rockets you my friend you have the wrong car right now. I love F-bodys, but let's face it in stock form they are not all tha fast. Yeah a good exhaust on an F-body is always going to help. Do you want to keep the cats or ditch them?
I understand my 91 isn't going to be as fast as other cars. My goals are realistic. 250 whp, reliable daily driver. Not looking for anything much. High 13's or low 14's would work for me. I saw my baby on the lot and fell in love with it. I have never in my life seen another Banshee 91-92 305 TPI 5 speed. So I know I have something very rare and it's been so good to me for almost a year. Literally zero problems besides a little TLC last owner didn't do.
Yesterday I got timing done, new battery, new alternator, new vacuum hoses and some other minor things. I already notice it's running significantly better and I've gained a lot of top end.
Car: 1984 camaro z28
Engine: sbc 383
Transmission: Th400
Axle/Gears: Moser 9", 4.11 gear
Open headers on a 305 wont pick up anything, you will lose your low end torque. With just shorties and a y-pipe you should have an optimum exhaust for your 305. I'd say go that route and then if you ever start modifying your 305 then maybe you can step up.
Also, no stock 305 will run high 13's in the 1/4 mile. There are guys who ran faster than that on here, but they had some extensive mods to their car. My 305 with headers and y-pipe and ac delete ran 15.90's.
Currently I have just the stock manifold+midpipe. My muffler rusted bad so I removed the axel back (so no muffler)... just in case anybody is wondering what I currently am stuck with. If I do headers+y pipe... what brands/set ups do you recommend? Ideally I'd want the easiest/most efficient job. I'd love to run catless but not sure if the 305 will throw a check engine light?
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
I'm sure you know significantly more about F Bodies than me... but remember I have a 91 5 speed. Bigger head and cam so these power goals should be easier to achieve. I didn't mean 13's stock man . I meant eventually WITH mods I'd love to be high 13's. Which gives me a quick but not fast car. Peppy daily driver.
Look up Dyno Don and get his headers. They are the best bang out there and you can run dual cats. Then get a 3in cat back exhaust system from Magnaflow. It will be a cool mellow deep sound and you car will run in the high to mid 13's if you can drive @ 101mph in the quarter mile. I've seem it done before. The headers are not cheap but they will not rust and will last the life time of the car.
Dyno Dons headers and Y pipe. along with a cat back of your choice. For the power your looking at this will be more than enuff. Plus you can keep your cats and all your emissions stuff to keep it a true daily driver out there in ****-ville.. lol
Do some looking and you will find great info.
Young dude, you are tripping. You can not run open headers on a V8 car period. And no smog stuff either? Big tickets and big *** fines up to $5000 for tampering with the emissions equipment.
I'll look into Dyno Don right now. I'm starting to wonder if I should just start with heads/cam at this point. The local shop said if I bring him parts he will do the job for 600 or 700 bucks. With the full headers+exhaust I'm not looking at much less and I'm sure the gains of heads/cam would be SIGNIFICANTLY more.
Problem is I'm sure I'd have to buy a custom chip and all kinds of crap. I always thought 80's and 90's small blocks were easy to mod up but man... these 3rd gens seem to cost a ton to mod.
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
I already have my story ready for a cop . "My muffler rusted out and I'm a broke college student so saving for an exhaust now". Which is actually the truth! . Damn I didn't realize the fine can be 5000 bucks though .
It's not expensive in comparison to other cars. You have a 305 though, and those require some serious work if you want to keep up with "everyone else".
Car: 84 Trans Am
Engine: Turbo 301
Aye Clipperman, nothing like the sound of open hedders on a hot rod V8. I once (many yrs ago), uncorked my Doug Thorleys on a military vacation, for a full tank of gas, driving from LRAFB Ark to Mass. It was all hy-way driving, (65 GTO),and wanted to experiment for the sake of fuel mileage. It didn't do much for that, but made me feel like Richard Petty, everytime I got to pass someone. How it would effect your computer or little 305 I can't say, but it sure is fun. (Unless you get caught and have to pay the piper.). Your choice. Good luck.
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I had short pipes and glass packs exiting under the floor of a 454HO in a '67 Firebird. I did 400 miles on the freeway with them. Never again. OK for cruising around town at low revs with an occasional blast. Especially in a tunnel. But hours on end? No way.
Yea my WRX was ear bleeding. Anybody here have a 91-92 that has a recommendation on the best headers/exhaust combo? I don't care about loudness but purely power gains.
1 Post
Car: '91 Firebird '85 Firebird
What the flying F is a Banshee? Are you just referring to a aero kitt'd firebird? And since 305's were the only ones to get 5-speeds im sorry to say your car is not rare at all. Infact its common as hell.
1 Post
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
The Banshee is what the original Pontiac concept car was called that the '91 '92 body style is based on. It can probably be Googled.
Point is... If you're gonna be a douche at least do the research.
http://www.autotrader.com/cars-for-s...Radius=0&Log=0
Searched for 91 5 speed Trans Am on auto trader with no distance restriction and guess what I got? ONE.
Cars.com had zero matches to that criteria. Those are the two biggest used cars searches on the web. Yup... very common, dime a dozen.
Just found another thread on this board that said only 154.. 5 speeds were made for 91 Trans Am. So yup... Pretty damn rare. Another example of 5 speed rarity can be seen in the 91Camaro. 100k total Camaro's were made and only 15k had a 5 speed. That includes all trims and all 3 engines.
Anyways this is off topic. Only reason I specified my car was because 90 percent of the threads here are for 350's or pre 91's. Which is no good to me because I have 2 cats, speed density and bigger stock head and cam than both automatics and previous years.
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
dont know if this helps but i live in reno like you said you used to and i ran open headers on my 350 for like a year straight (car is being rebuilt and will probably have open headers when back on the road) and never got pulled over by the cops but when my car was e.f.i. the open headers made the knock sensor go off and retarded the timing ....... so open headers will hurt ur efi performance if its anything like my experience. but i have taking my newly carbed motor out with open headers and it was loud and fun as hell. .......... not sure if any of this makes sense i just got back from my 10 reunion and i am kinda wasted ...... hope my post helped
Car: 84 Trans Am
Engine: Turbo 301
Yup... very common, dime a dozen.[/quote]
LMFAO
LMFAO
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
I have run open headers on a few vehicles. I have never looked back or regretted it either. I did a ten hour trip on a open header 302 V8 Bronco and I didn't get tired of that sound once!
Haha... on my WRX I told you guys I ran open DP. I also never got tired of it despite my car shaking like crazy and people asking me wtf is wrong with my car. The only louder car I've run into was an older 2nd gen Camaro fully built with crate motor. Point is... like you, the noise doesn't bug me at all. The biggest problem though is remember I'm in California... where cops are car ****'s. They want any excuse to pull you over or crush your car.
mdtoren
08-16-2015 05:45 PM
