is it possible to have true dual exhaust on 89 iroc? anybody ever done it?
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
i got a 89 iroc has borla exhaust im trying to make it louder maybe going str8 pipe after cat. or trying to see if tru dual exhaust is possible for this 3rd gens.
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
Re: is it possible to have true dual exhaust on 89 iroc? anybody ever done it?
its possible to put it on it ive got true duals exhaust on mine
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
its in my profile cant fig out how to post it in here yet
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
never mind there it is lol true duals
Car: 84 camaro
Engine: 305 H.O
it is possible but if your using 3 inch pipe its going to hang awfuly low, id watch for speedbumps ive heard horror storied of people ripping there pipes off or damaging them something feirce, "dusty'
s89" what size is your exsaust?, it seems as if your pipes are hanging down a wee bit
i got edelbrock headers and trying to go 3 inch pipe, but im trying to put them on out to the side,infront of the back tires. Dusty ur exhaust looks nice
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
ive got hooker headers and the pipes are 2/1-2 dynomax mufflers they do drag i slow down enough they dont
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Whats wrong with a super single? Like 3"? I know duels are cool and all, but the cars are not set up for them and most of the set up's I have seen around here hang too low and look nasty. If done right just about anything will work out, but IMO a single pipe on a stock or light modded car is just fine and sounds great.
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
I'd do a 3" single. I think you lose ground clearance with true duals. Even if you dont it wouldnt be an easy install, there's not much space under our cars to work with
Engine: 5.0 L03 V8
just read the original post if you want to make it louder I recommend getting an exhaust cut out.
i have full 3 inch true dual exhaust each header has a pipe goin straight out the back. the piping does hang very low i ll try n post pics
Ok how about 3inch single pipe but can u still have dual tips? Any pics? I did it on my transam it sounded nice but it was a shitty job the exhaust shop did so yea anybody has that?
Engine: 5.0 L03 V8
up top is a section of my exhaust set up and below is my 3 or 3.5" dual tips.
Car: 1987 IROC Z28 Camaro
Engine: HSR L98
Axle/Gears: stock
The way i've done my true duals is perfect (at least for me). I took it to the city not long ago and went over whatever speed bump I could find and it never scraped.
Hooker 2046, 2.5 inch pipe, and short powersticks make for a very, very loud exhaust. Out in the countryside people do not mind, but i've been pulled over twice going through the city.
Here's a vid of how I ran it
http://www.youtube.com/watch?v=ovxBrUWHYbw
Car: 1987 IROC Z28
Engine: LB9
Axle/Gears: 9 Bolt w/3.27's
yes but its not a simple task. if i wanted noise, i would just get an exhaust cutout. they are cheaper and less work than true duals and when u uncap its louder than true duals.
