firebird true duals?
Car: 88 Firebird
Engine: 305 T.B.I
is it possivle to run true duals on a firebird? if so can u let me know how to do it if its not can u tell me whats the best exhaust to run...its and 88 with a 305
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: firebird true duals?
Please read this sticky at the top of this forum:
https://www.thirdgen.org/forums/exha...l-exhaust.html
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
It's possible but not practical or really needed. Usually with 2.5" inch pipe you have okay ground clearance. You could always have an exhaust made with 3.5-4" piping and you would probably be fine and maintain the ground clearance you have now.
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Possible yes, but not practical nor legal on an Registered/Inspected street car. A 2.5" will be plenty on your TBI 305.
Car: GTA
Mufflers aer a personal choice of do you like loud all the time? Quiet at cruise & loud only at WOT? Quiet 24/7? Throaty? Deep & mellow? Lots of choices & about all I can suggest is to listen to peoples video/sound clips & find out their cars specs & find one close to yours. A carbd 383 will not sound like your TBI 305. A LS1 sounds nothing like a SBC due to the different firing order to start with. LT1s are closer, but still no real close.
ambainb
04-25-2016 09:21 PM
