Stock Exhaust size
Car: 85 IROC
Axle/Gears: 3.42 Std. (3.73 posi, next winter)
Stock Exhaust size
Is the stock intermediate pipe on the 85 305 TPI 2.5 inch or 3 inch?
I already have a flowmaster installed by PO. The current intermediate pipe is hand made from some shabby mufler shop and is cracked going over the axle (looks like they used cheap pipe and bad bending work).
I have a local shop that will install a new factory replacement intermediate pipe that is pre-bent for my application for $175 parts and labor installed to my current flowmaster and tailpipes.
I am most likely going to remove the cat as I do not have emissions testing now that the car is 25+ years old.
I am running stock motor, no upgrades.
Is is worth the extra money to buy a "cat-back" system in place of fixing what I have, It seems like I would not gain much HP with the stock set up, remember I already have an aftermarket muffler....
Car: 85 IROC
Re: Stock Exhaust size
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
I'd go with a 3" cat-back, since yours is 2.5". Also, be prepared for the fact that the shop may not want to remove your converter, since that would technically be a violation of federal law, even if your state doesn't require it anymore.
Oh, and that stock replacement pipe is aluminized, though in Texas that may not be as big of a deal. Around here they last about 3-4 years...
Car: 85 IROC
And the cat mod will not be a problem for me to get done, wether this shop does it or not.
I'm thinking with the cat removal and the flowmaster that is already on the car, it should be plenty of free breathing for the stock set up. This is just a "weekend cruiser".
Car: 84 Z28
Personally, I'd say it is worth it, but that's just me
I'm sure the 2.5" will be fine for your car though. I was merely suggesting that an aftermarket system might be of better quality that the "OE replacement". If it's 2.5" with mandrel bends, then I'd go for it.
I saw "pre-bent factory replacement" and shuddered. It sounds like you have a decent shop to work with, so if that price is for quality work, it sounds like a winner
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Yea but is the 3" really worth the money on a stock 305 tpi with no mods? I found the stock 2.5" intermediate pipe at a shop that has the mandrel bends that they will install for $100 (even better deal than the other shop). The pipe is made by IMCO Performance.
toronto formula
11-10-2015 06:17 AM
Linson
08-21-2015 02:12 PM
knight72
08-10-2015 09:32 PM
