Best header seals/gasket?
Car: 1991 Z-28
Engine: 5.7L(350ci) TPI L98
Axle/Gears: G92
To start off, I have a 1991 Z28 with a stock L98. I recently purchased Dyno Don's headers, and was recommended to get the seals from earlsplumbing. Well they have now been on backorder for 2 months (I havent had time to work on the car, so it wasnt an issue until now.)
I would just like to know which brand/material/etc header seals wouldbe best for my engine. It is a daily driver so i want something durable with the least chance for leaking
Feel freeto suggest specific part numbers.
Also, I am not that familiar with exhaust, so I am not sure whether i have a D port or O port or what, could someone please explain this to me. Thank you in advance for any help!:-):-)
Car: 84 trans am
Engine: 350 bored .020 over
Transmission: TH350 w/ stage 2 B&M shift kit
Axle/Gears: 9 bolt/3.27
Re: Best header seals/gasket?
Get a felpro gasket, they always work for me. Do not get anything Mr.Gasket it is cheap!
Engine: 4++,350 & 305 CIs
Fel-pro 1404 or 1405 or 1406 or 1407 ish
Use 1" bolts (3/8ths head) with anti-seize.
I have had really good luck with the thick graffite gasket and the locking header bolts
Car: 86 Camaro, IROC springs & bars
Engine: Mild 350,Q-jet,headers
Transmission: M-21, 12#flywheel
Axle/Gears: 98 7.5, 3.73 torsen.
Lots of materials & opinions on exh gsks. I personally prefer dead soft copper or aluminum. The coppers been on my truck for about 11 years, when reusing just use a small amount of red silicone, holds up well.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Percy's aluminum.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Fel-pro sucks! Get the other one mention above. They will never blow out like Fel-pro. Example, if paper gasket get wet or if the bolts come loose the gaskets will blow out of fall apart. The other can be reused.
Car: 1991 Z-28
Axle/Gears: G92
Well, I ordered the FelPro gaskets, as my plan was to use them in the car simply until the Earls Plumbing ones were off back order since the felpro were only like $15 with free shipping.... but surprise surprise, they told me at least 2 more weeks for the earls plumbing, but as soon as the fel pros shipped, half a day later the earls plumbing gaskets shipped! Oh well, I guess I'll just have an extra pair of SBC header gaskets now, its not like there aren't enough vehicles with 350s in them among my family and friends....
What are Earls made out of copper? That could be a stupid question.
Car: 1991 Z-28
Axle/Gears: G92
All right I have had good luck with this type of gasket and the locking header bolts.
Car: 1991 Z-28
Axle/Gears: G92
Great! I'm using those gaskets and the ARP bolts and washer kit for the headers.
You can look forward to a trouble free setup.
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
http://catalog.remflex.com/
Best headers gaskets I ever used. The only bad thing is they are not re-usable.
redformula88
10-14-2015 06:08 PM
