Exhaust touches oil pan.
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
It barely touches my oil pan.
What problems will this cause? Will it cause any?
Like I said its barley touching and It maneuverable I need to hang it up to my frame. So if I could put something there to prevent any damage like heat wrap or something just tell me.
Any suggestions welcome, thanks.
Not trying to bump or anything but if anyone can give me info that would be awesome. I did research and couldn't find anything, ill continue to look.
Last edited by xxZ28xx; 12-29-2011 at 11:30 AM. Reason: Working on my car now, this is the last thing I need to finish.
Re: Exhaust touches oil pan.
Here is a picture, see it just barely touches. There is no y pipe, its straight duals all the way back.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You do need to slow down and double check everything before you fire it up. If not, you might be in for a bigger setback.
As far as your exhaust pipe, can you loosen the flange and give it a little twist? Prying it might even bend it enough to keep it from touching. As a general rule, vibrating parts should never come in contact with each other. It makes wierd noises, but even worse, the thinner one will eventually rub through.
Oh wow! Thank you for that information I appreciate it.
If Im not able to get it away from there will it pose a really big problem? Like heating up my oil then my engine over heats and boom im done for
Engine: 4++,350 & 305 CIs
Wow someone messed up when they built that pipe..
Thanks Ill do what you suggested!
And its not that they built the pipe wrong, they were made for different headers. It even tells me that some cutting and bending may need to be done and if you look closely at the picture you can see I already added an extension lol. Almost made it!
But thanks for the advice! This is really good news, ill be on the road in no time! : )
downsouthboy
08-29-2015 11:29 AM
Navy8125
08-21-2015 09:32 AM
