Edelbrock TES Header fitment problems
Car: 1984 firebird S/E
Engine: 305 LG4
Axle/Gears: 3.08
Hi guys. i have a 1984 firebird s/e with the 305 lg4 block. i removed alot of unecessary emmisions equipment in the engine bay area to free up space and to make things simpler. I bought a used set of edelbrock tes headers with the air tubes. I attempted to fit the driver side header in and was not able to get it to fit. I can not figure it out. Please help as I am interested in how to get these headers to fit considering they were made for these cars. -thanks!
Re: Edelbrock TES Header fitment problems
Either disconnect the steering linkage or jack the motor up a little.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I had a set of Edelbrock's and they were incredibly easy to install, I managed to slide both in from the top with ease, are the brake lines getting in the way?
Engine: 305 LG4
Axle/Gears: 3.08
like spurgeon76 had stated, my steeting column/linkage is in the way. the brake lines not so much, but they are still slightly hitting on the drivers side.
Car: 83Z28 HO
Transmission: G Force 5 speed
Odd...I had to kinda tweak my brake lines for the DS header to fit, but I never had to disconnect the steering linkage. It's a tight fit, but the header slid past it. But as TTop350 posted, it's in the install directions...
Engine: 305 LG4
Axle/Gears: 3.08
I just got the headers in guys!!! WOOHOO. in the end there wasnt a fitment problem at all. the reason why my steering column was in the way because in the horozontal position it gets in the way when installing the headers, i turned the steering wheel and clang! they fell right into place. Just finsihed installing them! runs like a charm and is got damn loud. sounds better now with open headers compared to before when i was running just a exhaust cutout after the y pipe on my stock manifolds. i now need to purchase a aftermarket y-pipe. which one is the right one for the edelbrock TES headers?>
I believe you can find a replacement y-pipe on Summit.
http://www.summitracing.com/parts/EDL-25-9509/
Engine: 305 LG4
Axle/Gears: 3.08
yeah man, i was looking at that part last nigt. i dont know if i need the other part which is 35-25-9506. i believe it said like y pipe cross over extesnsion on something. would the part 25-9505 just do or do i need both parts? jegs has both parts while summit only has this one. beats me
35-25-9506- "Designed to replace stock pipe and give additional ground clearance of 1-5/8'' on lowered Chevrolet/GMC trucks. For use with stock exhaust manifolds or Edelbrock Shorty Headers."
This is not the one you need.
Car: 85 TA (sold), 88 Corvette, 02 Monte
You might need to know the model number of your headers. The edelbrocks have a few different collector diameters. There are also a couple different output diameters on the y pipes.
Engine: 305 LG4
Axle/Gears: 3.08
so the part number 9509 should work? -thanks!
kah992
08-19-2015 02:55 PM
