Need thicker header gaskets, Any ideas where to buy?
Car: '91 Camaro RS
Engine: 383 Stoker
Transmission: Pro-Built 700R4
Axle/Gears: 3.42 Detroit Locker Posi
I have a these headers Hooker 2460HKR and they came with a 1/16 gasket. I'm however having problems getting this thin gasket to seal. The flanges and the motor are not flat which is leaving space for exhaust leaks. A 1/8 thick gasket should be thick enough to make the seal good but I'm having problems finding a place that sells something thicker. Any ideas or a site to go too?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need thicker header gaskets, Any ideas where to buy?
Use dead-soft aluminum gaskets. Many manufacturers these days, ususally even just on the shelf in Autozone. They are slightly more than a 1/4 inch thick, but compress when installed, and seal really well.
Adv Auto carries Mr Gasket dead soft aluminum for SBC's
For on-line, order Percy's seal-4-good from the usual suspects jegs etc
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Be sure the flange is flat or no gasket will seal. Use a file to knock the high spots down, there shouldnt be much to worry about. Never had a problem with common paper gaskets when using high temp RTV and torquing the bolts in cycles
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
many , many times the cause of gasket leaks is improper preperation/installation . this is "NOT" a slam , make sure both surfaces are clean & flat . chase with a tap all mounting holes in head . clean holes with wd-40 or your choice with straw on can . install and torque "from the center out" . go back & re-torque from the center outward several times . did i mention torque from the center outward , center , rt. , lt. , rt. , lt. rt. , lt. one at a time with the bolts . start up , get warm re-torque a couple more times . good luck .
Car: 92 Firebird
![yup](https://www.thirdgen.org/forums/images/smilies/yup.gif)
As silly as it sounds, thats the exact process for torquing header bolts and you will do it quite a few times. Miss it once and the gasket will blow out forcing you to start the whole process over again
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
ive always manifold gaskets and had the best luck with them but like said correct torquing is needed.
You can double up a set of regular paper gaskets too.
1992 Trans Am
05-10-2023 07:19 PM
evilstuie
02-28-2016 03:33 PM
NinjaNife
08-23-2015 11:49 AM
mdtoren
08-16-2015 05:45 PM
