y pipe for hedman shortys
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
picked up a set of hedman shortys for a deal. would i be better off with running the hedman y pipe and mod it to 3in to mate with my cat and catback or build a custom one thats full 3in off each header and merge to the single. the full 3in may be a little over kill for the lb9 i do plan to keep it as long as possible but when the time comes and it gives up the ghost most likely a 350 will be built and swaped in. i mainly use the car for dd and autocross. also would i be better off putting the o2 bung in the y pipe just after it meets the header or in the header collector? thanks
LT1Formula
10-08-2015 08:34 PM
