do ram horn manifolds work to replace the stock manifold and are they better?
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Hello i was wondering if ram horn manifolds could replace the stock manifolds? I am doing this to get rid of the smog crap on them and dont want headers cause i dont want to have to do exhaust work. And i have read ram horns breath really well.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: do ram horn manifolds work to replace the stock manifold and are they better?
They won't fit a thirdgen.
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
what part wont fit? Is it cause they dont have any ram horns that have a diameter the correct size or? Cause arent the exhaust ports the same on a tpi as any other sbc?
Engine: 383 Carb
Transmission: 4L60
The K member is in the way.
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
ok thank you! Is there any other manifolds that i can replace with my stock ones to get rid of the smog and possibly pick up som hp with it?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can use the stock manifolds and get rid of the smog (assuming it's legal in your area to do so). Only other option is 3rd gen headers.
transaero
08-31-2015 01:14 AM
